imjolly
Message 11 of 17
Re: Fibre with Halo - way off minimum speeds?
stats are what looking for  connection time very short only couple hours was that a manual reset?
your connection speed is in line with your attainable speed but until see checker results can't tell what expected range is to compare
FullingMill
Message 12 of 17
It is a new hub, delivered today.
Last year, with the old hub and BT broadband, I regularly got 30-50Mbps.  However, in the past year, the connection seems to have slowed a great deal, hence 'upgrade' to another BT plan that said it 'guaranteed' a minimum of 30Gbps.....and thus my disappointment that the new tarif and hub is delivering no more than I got from the old set up before today.....and nothing like the speed when I first signed up to BT at this house 4 years ago.  Things seem to be moving backwards!
imjolly
Message 13 of 17
If you only were able to get between 30/50mb then that is all you line can handle and upgrading to a faster package was not going to improve your connection speed
still need dslchecker results
FullingMill
Message 14 of 17
30-50 would be great.....but I am getting about 12.
How do I show you dslchecker results?
FullingMill
Message 15 of 17
Would this be it?
BT BROADBAND AVAILABILITY CHECKER
Telephone Number 01256xxxxxx on Exchange WHITCHURCH is served by Cabinet 5
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date
ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)ADSL Availability DateWBC SOADSL Availability DateLeft in JumperObserved SpeedsVDSLOther Offerings
Availability Date
Premise environmentStatus
VDSL Range A (Clean)73.651.118.61245.9AvailableAvailable--
VDSL Range B (Impacted)70.945.41810.335.1AvailableAvailable--
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 13--7.5 to 17.5AvailableAvailable--
WBC ADSL 2+ Annex MUp to 13Up to 17.5 to 17.5AvailableAvailable--
ADSL MaxUp to 7--6 to 8AvailableAvailable--
WBC Fixed Rate2 ----AvailableAvailable--
Fixed Rate2 ----Available----
Max Observed Downstream Speed (Mbps)13.09
Max Upstream Observed Speed (Mbps)4.24
Observed Date2020-04-01
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapN
VRIN
NTEFaceplateN
Last Test Date05-09-2019
pippincp
Sage
Message 16 of 17
You should be getting 50+ speeds. You are going to have to ring it in.
FullingMill
Message 17 of 17
Thank you - BT has acknowledged problem and are sending out an engineer.
