Message 1 of 9
Fibre with old Hub
Help!
I have a Smart Hub - Type B .
I just had my connection upgraded to Fibre today but the OpenReach engineer told me I needed a new Hub so walked away without connecting it to the Hub.
BT say I don’t need a new Hub - that this one should work.
I’ve put the Ethernet cable between LAN1 and the modem but it’s all purple flashing lights. What can I try?!
8 REPLIES 8
Message 2 of 9
Re: Fibre with old Hub
Does the Hub have a Red WAN port if not try plugging into Yellow 4th Ethernet port.
Details here may help - https://www.bt.com/help/broadband/getting-set-up/how-to-set-up/bt-smart-hub-2/connection-modem
From a little more research it appears the Smart Hub does have a specific FTTP variant but it maybe a togglable option within the advanced setup but I don't know enough personally to confirm. It maybe you have the G.FAST compatible model not the FTTP one.
Message 3 of 9
@RDH
You need a Smart Hub 2, as that has a WAN port. Ring BT and ask for one.
Message 4 of 9
Hello. Thank you.
It doesn’t have a red WAN port.
Tried LAN 4 but still purple flashing.
So frustrating!
R
Message 5 of 9
There is one on order but I’m told (by BT!) this one should work too.
Message 6 of 9
To clarify, do you have a Smart hub(hub6) or a Smart Hub2?
Only the Smart hub 2 can configure LAN port 4 as a WAN port.
Message 7 of 9
It just says "Smart Hub - Type B" on the back.
I've been into the Admin and can't find any mention of FTTP toggles.
Message 8 of 9
BT staff as usual are clueless, that hub won't work with full fibre. You need a Smart Hub2.
Message 9 of 9
Thank you very much for your help.
