helenmac1cat
Message 1 of 5
Final attempt to find out what's wrong with my ping
This is my final attempt to find out what is wrong with my ping.
When I try and play online games, they become completely unplayable because very frequently but randomly the ping/latency (ping = milliseconds a request from your pc takes to get to server) spikes up from 20ms to 600ms! This makes it unplayable...
It happens on wired and wireless, any idea what's wrong?
4 REPLIES 4
Sage
Sage
Message 2 of 5
Re: Final attempt to find out what's wrong with my ping
A tracert would help. In windows 7 click the orb and enter cmd in the search box, open the cmd.exe and in the window type tracert bbc.co.uk post back a screenshot of the result.
Then access the HH5 and copy lines 1-12 in troubleshooting/helpdesk and post here.
helenmac1cat
Message 3 of 5
Here's the tracert result to bbc http://pastebin.com/V4PKfksL
But you have to rememeber when i'm playing the http://pastebin.com/3hmGHS9K
 Here's the helpdesk:
1. Product name:BT Home Hub
2. Serial number:+068343+NQ34341979
3. Firmware version:Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated 15/01/14
4. Board version:BT Hub 5A
5. VDSL uptime:0 days, 11:30:25
6. Data rate:15142 / 69665
7. Maximum data rate:15041 / 68761
8. Noise margin:5.9 / 6.2
9. Line attenuation:0.0 / 18.5
10. Signal attenuation:0.0 / 18.5
11. Data sent/received:485.9 MB / 1.6 GB
12. Broadband username:bthomehub@btbroadband.com
Distinguished Guru
Message 4 of 5
Are you doing these traceroutes over wireless?
If not, I'll try again 🙂
Tony-gbr
Message 5 of 5
Buy an open reach modem. Seems like a lot of peoples routers have screwed up their connections after a recent firmware update for the hh5. I haven't disconnected since using an openreach modem. Got an engineer coming out Monday because I want to be put back on fast path or have my DLM reset. Whatever restores my ping. If engineer refuses I'll just keep calling BT and getting the engineer back out lol
