Anonymous
Not applicable
Message 11 of 16
Re: Flashing PON light
Glad you're sorted but it may be useful for others if you could detail through which channel you were able to get Openreach involved.
Message 12 of 16
Hi, I’m pretty sure I’m having the same issue. How did you manage to reach out to openreach directly? They have no customer service for broadband installations AFAIK
Message 13 of 16
if you are a BT broadband customer you need to phone CS 03301234150 and report fault  have you check for problems in your area in case just not you with problems
Message 14 of 16
I’ve called EE/BT CS multiple times and have had no success. Been without working internet for over a month now. They can’t get anyone at Openreach to come and check the issue, just get told it’s been escalated every week. Very disappointing
Message 15 of 16
are you a BT broadband customer?
have you checked for outages in your area?
Message 16 of 16
Start talking about your right to terminate and leave.  That should get them moving, although ultimately, even BT are dependent of Openreach getting their finger out.
