Message 11 of 14
Re: Flat doesn’t get fibre but building does
Thanks for all your help with this. I guess I will look around and then phone since online isn’t giving the option.
Would it be more helpful to contact Openreach directly? Is that possible?
Message 12 of 14
no  you are not openreach customer
you can try  https://www.openreach.com/fibre-checker
Message 13 of 14
You can't contact Openreach directly, they are not customer facing.
Message 14 of 14
Thanks. I tried the fibre checker on Openreach which has flat 3 in the building as having up to 300+ but doesn’t have have ours (flat 2) having any options at all so I will look at filling out the form to say there’s an error
