Distinguished Guru
Distinguished Guru
Message 11 of 11
Re: For an overhead FTTP supply, can a CSP be mounted inside the building - or is one necessary
@OldGoat wrote:
Seemples -
seemples - OpenReach is a wholly owned subsidiary of BT and in essence does what BT tells it to.
The service supply companies - including the customer arm of BT all have the same acccess to OR's system - but no further. Thus if there's a logjam / serious problem there is no way of a consumer getting a fix - except throuhg OR - to which he has no access; because that's the way the system was designed.
If you say so.
