JimFraggle
Message 1 of 11
Free 76Mb upgrade never happened
Today I've had an issue sorted with my Infinity 1 line which I think has been there a while - was only getting 36 down and 3 up. Not back to full 55 down, 10 up. However, I've done a chat with BT and they say I won't get the 76 free upgrade because my line can't support it.
However when I first signed up with Infinity 1, I was getting 76 down, 18 up for several months even though I was on the Infinity 1 package. I wonder if they did their tests for the upgrade when my line had the problem.
Is there a way to get the upgrade applied now?
10 REPLIES 10
imjolly
Message 2 of 11
Re: Free 76Mb upgrade never happened
post the stats from your router  if hh6 then advanced settings then technical log information
enter your phone number and post results  remember delete number  http://dslchecker.bt.com/adsl/adslchecker.welcome
JimFraggle
Message 3 of 11
Product name:
BT Hub 6A
Serial number:
+084316+NQ64208381
Firmware version:
SG4B1000B540
Firmware updated:
08-Apr-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 1 Hours 10 Minutes 9 Seconds
Data rate:
10.00 Mbps / 55.00 Mbps
Maximum data rate:
25604 / 81328
Noise margin:
22 dB / 12.9 dB
Line attenuation:
11.2 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
28760 MB Uploaded / 29279 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date   ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date Left in JumperOther Offerings     Availability Date   Premise environmentStatus
VDSL Range A (Clean)8060201953AvailableAvailable--
VDSL Range B (Impacted)73.945.62015.338.2AvailableAvailable--
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 15.5--11.5 to 19.5Available----
WBC ADSL 2+ Annex MUp to 15.5Up to 111.5 to 19.5Available----
ADSL MaxUp to 8--7 to 8Available----
WBC Fixed Rate2----Available----
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapN
VRIN
NTEFaceplateN
Last Test Date19-04-2018
imjolly
Message 4 of 11
your line can obviously support infinity 2 and is currently on infinity 1 max
do you qualify  http://bt.custhelp.com/app/answers/detail/a_id/56165/~/questions-about-the-bt-infinity-1-speed-upgra...
JimFraggle
Message 5 of 11
Yes I've been on Infinity 1 since December 2016, so presumably I'm eligible. I wonder if the issue I had with my line was causing problems when they ran their upgrade capability check?
imjolly
Message 6 of 11
I have asked forum mods to see if they can help you    they will post here with a link
RobbieMac
Moderator
Moderator
Message 7 of 11
Hi @JimFraggle
Welcome to the community and thanks for your post!
I'll be able to check what happened the free speed boost and if you're eligible for it.  I know that these were happening at the end of last year.
Click on my username here >> RobbieMac << and you'll see our contact link underneath my profile picture.
Cheers,
Robbie
PaddyB
Moderator
Moderator
Message 8 of 11
Hi @JimFraggle,
Thank you for sending in your details. I gave your mobile number a quick call, I'm sorry I didn't get speaking to you today.
I've had a look at the details of your account and I can confirm that you were entitled to the speed boost. I've placed an order to increase your speeds which is due to complete tomorrow. I'll follow up with you again on Thursday to confirm the order has completed correctly.
PaddyB
JimFraggle
Message 9 of 11
Marvellous, many thanks!
PaddyB
Moderator
Moderator
Message 10 of 11
Hi @JimFraggle,
I've ran a few checks on your connection and I can see that your speeds have increase to 77 Mbps, which is good to see.
If you need anything else, please get back to me?
PaddyB
