Techwizz
Message 21 of 47
Re: Free "upgrade" has reduced my download speed?
Will be interesting if you can find a phone, as if there's noise on the line, then we'll know that's causing the problem.
Message 22 of 47
If you are now in test socket with a filter then can you repost your router stats to compare
elsouthward
Message 23 of 47
Pretty much the same. Might be able to borrow a phone tomorrow afternoon.
elsouthward
Message 24 of 47
So the enginner attended and tried everything he could but said there was no visible fault and there was nothing he could do to improve the speeds. He suggested i needed to arrange a "boost engineer" visit, how do I go about doing that?
Techwizz
Message 25 of 47
The mods should be able to do that.
Message 26 of 47
i Have asked mods to see if they can help  they will post here
elsouthward
Message 27 of 47
Thanks very much.
Moderator
Moderator
Message 28 of 47
Hi @elsouthward  sorry the engineer visit did not help get your speed increased.
I've sent you a Private message explaining how you can contact the forum moderation team.
Check here: https://community.bt.com/t5/notes/privatenotespage
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Gary_C
Message 29 of 47
As far as I can see, the down stream Noise margin is 6.1dB ? So its synched about as far as its going to get as 0.1dB is only going to gain about 1k ?
elsouthward
Message 30 of 47
Yes. When I first moved into this house I had 65Mb sync with a different provider, after switching to Infinity 1 it was locked at 55Mb as per their cap. Since the switch to inifinity 2, the degredation has become apparent.
