Message 21 of 145
Re: Free speed upgrade for Infinity 1 customers Sept-Nov 2017
Thanks @imjolly. I can now see that this 'boost' has the potential of being a bit of a damp squib for me if they raised it only to drop it back to the levels I was getting. Maybe it will go back up if the DLM settles as you point out. Thanks.
EDIT - one final question for you if I may, do you feel it would be best to leave my setup as is and not swap over the router for the smart hub?
FURTHER EDIT - hope you can stick with all these edits @imjolly. I've just been going over some of my previous stats for my router and noticed that on the two occasions I had the 63 speeds my noise margin was at 3.6 so I guess the potential for that speed boost again is very much alive. Fingers and toes crossed Smiley Happy
Message 22 of 145
your setup looks ok and working fine so I would not go rushing to use the HH6  my hh6 works without problems but others are not so lucky
Message 23 of 145
Good to know. Thank you Smiley Happy
Message 24 of 145
Sounds like DLM decided your connection was unstable with the faster speeds. A smarthub might make all the difference.
Sage
Message 25 of 145
Won't make any difference at all. Can't see how you assume it would.
Message 26 of 145
Because the TP link has a lantiq chipset and the smarthub has the superior Broadcom chipset
Message 27 of 145
@MadRob
as I said I wouldn't change at present for the HH6 - but your choice  remember you want a stable conenction not switching routers and then maybe have to switch back
Message 28 of 145
@DavidM wrote:
Hi @kkkk and thanks for posting.
I'm sure we can clear things up for you. Can you confirm if you're on Infinity 1 or 2? Can you try running the speed test including the further diagnostics and post the results?
Cheers
David
Hi David, I have posted all the info in the thread, I wonder if you could investigate please.
Moderator
Moderator
Message 29 of 145
Hi @kkkk
Click on my username here >> RobbieMac << and you'll see our contact link on the left hand side underneath my profile picture.
Cheers,
Robbie
Message 30 of 145
Hi, there is no link under your picture... only 'send me a private message' on the right...
