Message 11 of 17
Re: Frequent BT Fibre disconnects that OpenReach can never trace.
In this case PPPoE session logs from both the BT  end and the router.
Like I said and the point seems to have been missed somehow, it's even there in the logs, the PPPoE session is dropping not the VDSL line.
Message 12 of 17
Hi - apologies but I don't know what that means.
I created manually the log files to show only the PPPoE - there is no option to select VDSL on my BT router.
Also, why do the router logs for UPNP/DNS show a change of date to 01 JAN.
00:01:49, 01 Jan.
BR_LAN:UPnP functionality has been activated
00:01:49, 01 Jan.
BR_LAN:UPnP functionality has been deactivated (manually)
00:00:55, 01 Jan.
Message 13 of 17
The Hub might not have picked up the time from the NTP server, or just kept the logs relative to the default time from when the hub was switched on.
You can get a good idea if the VDSL line droped from the technical info, I have no idea if the recent BT smart hubs reset the Connection uptime on DSL, PPPOE or both. if the time exceeds the last PPPoE drop is safe to assume that the DSL up time exceeds the PPPoE session.
The normal reason for a PPPoE session to drop is the DSL line dropping out or erroring.
Message 14 of 17
would it help if I posted all the router info from the time of the drop out, instead of only the PPPoE which is what I filtered on?
Router Stats?
11:12:51, 25 May.
dsl:VDSL Link Down: duration was 1007 seconds
Message 15 of 17
@Hangerheadwrote:
All I get is a pre recorded msg. This number does nor accept income calls.
Just to check you dialled: 17070? You should get "this circuit is defined as (will read out your landline number) , welcome to your Openreach line test facilities" - followed by a list of options.  Can you re-dial and check it again?
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 16 of 17
That number worked - a little bit noisy which is part of previous complaint to BT - gets resolved temporrily and then worsens.
logs for 2 separate dropouts.
11:13:01, 25 May.
wl1:A WiFi device <0C:47:C9:53:13:07> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
11:13:00, 25 May.
wl1:Device <0C:47:C9:53:13:07> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
11:12:58, 25 May.
wl1:(1/6) Channel Hopping initiated/Manually initiated
11:12:55, 25 May.
:VLAN VLAN_DATA disconnected
11:12:55, 25 May.
:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
11:12:54, 25 May.
BR_LAN:The LAN DHCPv6 Server is active
11:12:53, 25 May.
ppp1:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
11:12:53, 25 May.
ppp1:The DYN ROUTE [81.139.56.100/32 gw 172.16.14.188] is deleted
11:12:53, 25 May.
ppp1:The DYN ROUTE [81.139.57.100/32 gw 172.16.14.188] is deleted
11:12:53, 25 May.
BR_LAN:The LAN DHCPv6 Server is inactive
11:12:52, 25 May.
11:12:52, 25 May.
BR_LAN:LAN Router Advertisement Setting Updated : M_flag = 0, O_flag = 1
11:12:52, 25 May.
11:12:52, 25 May.
ppp1:The WAN DHCPv6 Client Process has successfully been terminated on Vlan 36
11:12:52, 25 May.
11:12:52, 25 May.
11:12:51, 25 May.
BR_LAN: Allocated prefix = fdaa:bbcc:ddee::/64 (valid time = 4293967296 / preferred time = 4293967296)
11:12:51, 25 May.
BR_LAN: Revoked prefix = 2a00:23c6:7487:fb00::/64 (valid time = 2026291200 / preferred time = 2026291200)
11:12:51, 25 May.
ppp1: Revoked prefix = 2a00:23c6:7487:fb01::/64 (valid time = 2026291200 / preferred time = 2026291200)
11:12:51, 25 May.
ppp1: Revoked prefix = 2a00:23c6:7487:fb00::/56 (valid time = 2026291200 / preferred time = 2026291200)
11:12:51, 25 May.
10:56:51, 25 May.
wl1:A WiFi device <A8:DB:03:B1:30:26> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
10:56:50, 25 May.
wl0:Device <A8:DB:03:B1:30:26> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
10:56:49, 25 May.
wl1:Device <A8:DB:03:B1:30:26> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
10:56:49, 25 May.
wl1:IGMP group 224.0.1.187 on interface wl1 ended by 192.168.1.206
10:56:48, 25 May.
:WAN DHCPv6 Client Prefix : 2a00:23c6:7487:fb00::/56 (valid time = 315360000 / preferred time = 315360000)
10:56:46, 25 May.
10:56:46, 25 May.
10:56:46, 25 May.
10:56:46, 25 May.
BR_LAN: Allocated prefix = 2a00:23c6:7487:fb00::/64 (valid time = 2026291200 / preferred time = 2026291200)
10:56:46, 25 May.
BR_LAN: Allocated address = 2a00:23c6:7487:fb00:2620:c7ff:fe66:7c89 (valid time = 2026291200 / preferred time = 2026291200)
10:56:46, 25 May.
10:56:46, 25 May.
ppp1: Allocated prefix = 2a00:23c6:7487:fb01::/64 (valid time = 2026291200 / preferred time = 2026291200)
10:56:46, 25 May.
ppp1: Allocated prefix = 2a00:23c6:7487:fb00::/56 (valid time = 2026291200 / preferred time = 2026291200)
10:56:46, 25 May.
ppp1: Allocated address = 2a00:23c6:7487:fb01:2620:c7ff:fe66:7c87 (valid time = 2026291200 / preferred time = 2026291200)
10:56:46, 25 May.
10:56:46, 25 May.
10:56:46, 25 May.
ppp1:The WAN DHCPv6 Client Process has successfully been launched on Vlan 36
10:56:45, 25 May.
10:56:45, 25 May.
10:56:45, 25 May.
10:56:45, 25 May.
10:56:45, 25 May.
10:56:45, 25 May.
10:56:45, 25 May.
10:56:45, 25 May.
10:56:45, 25 May.
10:56:45, 25 May.
10:56:45, 25 May.
10:56:45, 25 May.
10:56:45, 25 May.
10:56:45, 25 May.
10:56:45, 25 May.
10:56:45, 25 May.
10:56:45, 25 May.
10:56:45, 25 May.
10:56:45, 25 May.
10:56:45, 25 May.
ppp1:WAN DHCPv6 Mode : Statefull
10:56:44, 25 May.
10:56:44, 25 May.
10:56:44, 25 May.
10:56:44, 25 May.
10:56:44, 25 May.
BR_LAN: Allocated prefix = 2a00:23c6:7487:fb00::/64 (valid time = 240000000 / preferred time = 0)
10:56:43, 25 May.
ppp1: Allocated prefix = 2a00:23c6:7487:fb01::/64 (valid time = 240000000 / preferred time = 0)
10:56:43, 25 May.
10:56:43, 25 May.
10:56:43, 25 May.
10:56:43, 25 May.
10:56:43, 25 May.
10:56:43, 25 May.
wl0:A WiFi device <A8:DB:03:B1:30:26> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
10:56:42, 25 May.
10:56:42, 25 May.
10:56:42, 25 May.
10:56:42, 25 May.
10:56:41, 25 May.
10:56:41, 25 May.
10:56:41, 25 May.
10:56:41, 25 May.
10:56:41, 25 May.
ppp1: Allocated prefix = 2a00:23c6:7487:fb00::/56 (valid time = 240000000 / preferred time = 0)
10:56:41, 25 May.
10:56:41, 25 May.
ppp1:WAN Router Discovery Setting Updated : M_flag = 1, O_flag = 0
10:56:41, 25 May.
10:56:41, 25 May.
10:56:40, 25 May.
10:56:39, 25 May.
:WAN: SENSING AUTO VDSL
10:56:39, 25 May.
10:56:39, 25 May.
10:56:39, 25 May.
ppp1:New DYN ROUTE is added [81.139.56.100/32 gw 172.16.14.188]
10:56:39, 25 May.
ppp1:New DYN ROUTE is added [81.139.57.100/32 gw 172.16.14.188]
10:56:39, 25 May.
wl1:IGMP join received for group 224.0.1.187 on interface wl1
10:56:39, 25 May.
ppp1:PPP: PPP INFO 81.139.57.100,81.139.56.100
10:56:39, 25 May.
10:56:39, 25 May.
10:56:39, 25 May.
10:56:38, 25 May.
10:56:38, 25 May.
10:56:38, 25 May.
ppp1:PPP: PPP INFO
10:56:38, 25 May.
ppp:PPP: IPCP_NAK
10:56:38, 25 May.
ppp:PPP: CHAP_SUCCESS
10:56:38, 25 May.
ppp:PPP: CHAP_RESPONSE
10:56:38, 25 May.
ppp:PPP: LCP_GOOD_ACK
10:56:38, 25 May.
ppp:PPP: LCP_REQUEST
10:56:38, 25 May.
:PPPoE error: timeout
10:56:22, 25 May.
10:56:14, 25 May.
10:56:10, 25 May.
10:56:09, 25 May.
10:56:09, 25 May.
wl1:IGMP group 224.0.1.187 on interface wl1 started by 192.168.1.206
10:56:09, 25 May.
wl1:IGMP group 224.0.1.187 on interface wl1 by 192.168.1.206 requested
10:56:05, 25 May.
ptm0.101:VLAN VLAN_DATA connected
10:56:05, 25 May.
:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
10:56:05, 25 May.
:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
10:56:05, 25 May.
dsl:VDSL link Up: Down Rate=74239Kbps, Up Rate=17000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
10:55:43, 25 May.
wl0:IGMP group 224.0.1.187 on interface wl0 ended by 192.168.1.240
10:55:43, 25 May.
10:55:43, 25 May.
10:55:42, 25 May.
10:55:42, 25 May.
10:55:41, 25 May.
10:55:41, 25 May.
10:55:41, 25 May.
10:55:40, 25 May.
10:55:40, 25 May.
10:55:40, 25 May.
10:55:40, 25 May.
10:55:40, 25 May.
10:55:40, 25 May.
10:55:40, 25 May.
10:55:40, 25 May.
10:55:39, 25 May.
10:55:39, 25 May.
10:55:39, 25 May.
dsl:VDSL Link Down: duration was 482 seconds
10:55:33, 25 May.
wl0:Device <D0:C5:F3:0C:5A:32> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
10:54:34, 25 May.
10:54:34, 25 May.
10:54:34, 25 May.
10:53:37, 25 May.
wl0:Device <38:53:9C:90:B2:C8> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
10:53:34, 25 May.
Message 17 of 17
Router Stats:
(NOISE Margin looks high?)
Product name:
BT Hub 6A
Serial number:
+084316+xxxxx
Firmware version:
SG4B1000E020
Firmware updated:
27-Mar-2020
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
1 Days, 0 Hours 57 Minutes 33 Seconds
Data rate:
17.00 Mbps / 49.00 Mbps
Maximum data rate:
29464 / 78027
Noise margin:
14.1 dB / 13.8 dB
Line attenuation:
21 dB
Signal attenuation:
13.4 dB / 21 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
9 GB Uploaded / 24 GB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
xxxxx
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
xxxx
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
xxxx
Software variant:
Boot loader:
7.33.1
