Moderator
Moderator
Message 11 of 31
Re: Frequent disconnections - multiple times per day
Hi @drewb,
I gave your mobile number a quick call, I'm sorry I didn't get speaking to you today.
The reason for my call was to see how things are with your connection following the engineer's visit? I ran a few checks on your line and its looking good so far.
I think is best to leave it for a few days, I'll follow up with you again on Monday to see how the connection is performing.
PaddyB
drewb
Message 12 of 31
Its been raining all day and the line has been rock solid.  The sync speed and max rate is much higher than we have ever achieved so I would say it is looking promising and switching the line from the property back to the cabinet has worked.
1. Product name:BT Home Hub
2. Serial number:+068343+NQ60325620
3. Firmware version:Software version 4.7.5.1.83.8.236.1.2 (Type A) Last updated 09/07/17
4. Board version:BT Hub 5A
5. DSL uptime:1 days, 07:53:27
6. Data rate:9999 / 55000
7. Maximum data rate:26889 / 72265
8. Noise margin:22.2 / 7.8
9. Line attenuation:19.6 / 16.0
10. Signal attenuation:19.6 / 16.0
11. Data sent/received:34.2 GB / 44.0 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:BTHub5-TFQH
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:BTHub5-TFQH
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:90:72:82:74:d6:62
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
Moderator
Moderator
Message 13 of 31
@drewb that's a great result I'm glad it appears to be sorted. I'll make sure that @PaddyB gets your message on Monday when he's back in the office.
drewb
Message 14 of 31
Second disconnection
06:38:45, 04 Nov.(22648.300000) Lease for IP 192.168.1.69 renewed by host Unknown-​00-​22-​61-​01-​e0-​63 (MAC 00:22:61:01:e0:63). Lease duration: 1440 min
06:38:45, 04 Nov.(22648.300000) Device connected: Hostname: Unknown-​00-​22-​61-​01-​e0-​63 IP: 192.168.1.69 MAC: 00:22:61:01:e0:63 Lease time: 1440 min. Link rate: 25.5 Mbps
06:38:45, 04 Nov.(22648.230000) Lease requested
06:38:44, 04 Nov.ath00: STA 00:22:61:01:e0:63 IEEE 802.11: Client associated
06:38:43, 04 Nov.OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.66]:59355-​>[74.125.133.188]:5228 on ppp3)
06:38:38, 04 Nov.(22640.720000) CWMP: session completed successfully
06:38:37, 04 Nov.(22640.010000) Lease for IP 192.168.1.66 renewed by host Chromecast (MAC 6c:ad:f8:87:42:8f). Lease duration: 1440 min
06:38:37, 04 Nov.(22640.010000) Device connected: Hostname: Chromecast IP: 192.168.1.66 MAC: 6c:ad:f8:87:42:8f Lease time: 1440 min. Link rate: 60.2 Mbps
06:38:37, 04 Nov.(22639.940000) Lease requested
06:38:37, 04 Nov.(22639.870000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
06:38:34, 04 Nov.ath00: STA b0:05:94:4d:68:27 IEEE 802.11: Client associated
06:38:34, 04 Nov.ath00: STA 6c:ad:f8:87:42:8f IEEE 802.11: Client associated
06:38:34, 04 Nov.ath00: STA 6c:ad:f8:87:42:8f IEEE 802.11: Client disassociated
06:38:34, 04 Nov.ath00: STA 00:22:61:01:e0:63 IEEE 802.11: Client disassociated
06:38:31, 04 Nov.(22633.640000) Device disconnected: Hostname: Unknown-​00-​22-​61-​01-​e0-​63 IP: 192.168.1.69 MAC: 00:22:61:01:e0:63
06:38:31, 04 Nov.OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.68]:45801-​>[176.32.101.52]:443 on ppp3)
06:38:31, 04 Nov.ath00: STA b0:05:94:4d:68:27 IEEE 802.11: Client disassociated
06:38:30, 04 Nov.(22633.160000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
06:38:30, 04 Nov.(22633.150000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
06:38:24, 04 Nov.(22626.450000) WAN operating mode is VDSL
06:38:24, 04 Nov.(22626.450000) Last WAN operating mode was VDSL
06:38:22, 04 Nov.(22625.330000) PPP IPCP Receive Configuration ACK
06:38:22, 04 Nov.(22625.320000) PPP IPCP Send Configuration Request
06:38:22, 04 Nov.(22625.310000) PPP IPCP Receive Configuration NAK
06:38:22, 04 Nov.(22625.310000) PPP IPCP Send Configuration ACK
06:38:22, 04 Nov.(22625.310000) PPP IPCP Receive Configuration Request
06:38:21, 04 Nov.(22624.280000) CHAP Receive Challenge
06:38:21, 04 Nov.(22624.280000) Starting CHAP authentication with peer
06:38:21, 04 Nov.(22624.270000) PPP LCP Receive Configuration ACK
06:38:21, 04 Nov.(22624.270000) PPP LCP Send Configuration Request
06:38:21, 04 Nov.(22624.260000) PPP LCP Receive Configuration Reject
06:38:21, 04 Nov.(22624.260000) PPP LCP Send Configuration ACK
06:38:21, 04 Nov.(22624.260000) PPP LCP Receive Configuration Request
06:38:21, 04 Nov.(22624.260000) PPP LCP Send Configuration Request
06:37:37, 04 Nov.(22579.660000) CWMP: session closed due to error: Could not resolve host
06:37:32, 04 Nov.(22575.040000) PTM over DSL is up
06:37:31, 04 Nov.(22573.690000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
06:37:31, 04 Nov.(22573.680000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
06:37:00, 04 Nov.(22543.170000) CWMP: session closed due to error: Could not resolve host
06:37:00, 04 Nov.(22543.060000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
06:37:00, 04 Nov.(22543.050000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
06:37:00, 04 Nov.(22542.510000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
06:36:58, 04 Nov.(22540.770000) PTM over DSL is down after 374 minutes uptime
06:36:58, 04 Nov.(22540.770000) PPPoE is down after 373 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
06:36:54, 04 Nov.(22536.940000) PPP LCP Send Termination Request [User request]
drewb
Message 15 of 31
First Disconnection
00:23:48, 04 Nov.
( 151.210000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
00:23:48, 04 Nov.
ath00: STA 54:ae:27:45:e5:ea IEEE 802.11: Client disassociated
00:23:48, 04 Nov.
00:23:47, 04 Nov.
ath00: STA 54:ae:27:45:e5:ea IEEE 802.11: Client associated
00:23:47, 04 Nov.
00:23:46, 04 Nov.
ath00: STA b8:53:ac:55:f8:d5 IEEE 802.11: Client disassociated
00:23:46, 04 Nov.
ath00: STA cc:78:5f:f2:86:c1 IEEE 802.11: Client disassociated
00:23:44, 04 Nov.
( 146.840000) Device disconnected: Hostname: iPhone IP: 192.168.1.86 MAC: b8:53:ac:55:f8:d5
00:23:44, 04 Nov.
ath00: STA 44:65:0d:18:ae:d9 IEEE 802.11: Client disassociated
00:23:43, 04 Nov.
( 145.350000) NTP synchronization success!
00:23:42, 04 Nov.
00:23:39, 04 Nov.
( 141.800000) Device disconnected: Hostname: iPad-​2 IP: 192.168.1.76 MAC: cc:78:5f:f2:86:c1
00:23:39, 04 Nov.
( 141.800000) Device disconnected: Hostname: DrewRosies-​iPad IP: 192.168.1.84 MAC: 54:ae:27:45:e5:ea
00:23:39, 04 Nov.
( 141.800000) Device disconnected: Hostname: Chromecast IP: 192.168.1.66 MAC: 6c:ad:f8:87:42:8f
00:23:39, 04 Nov.
( 141.790000) Device disconnected: Hostname: PS4-​b0-​05-​94-​4d-​68-​27 IP: 192.168.1.64 MAC: b0:05:94:4d:68:27
00:23:39, 04 Nov.
( 141.280000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
00:23:39, 04 Nov.
( 141.270000) CWMP: Session start now. Event code(s): '1 BOOT,M Reboot,4 VALUE CHANGE'
00:23:39, 04 Nov.
00:23:33, 04 Nov.
( 135.290000) NTP synchronization start
00:23:32, 04 Nov.
( 134.310000) WAN operating mode is VDSL
00:23:32, 04 Nov.
( 134.310000) Last WAN operating mode was VDSL
00:23:31, 04 Nov.
( 133.100000) PPP IPCP Receive Configuration ACK
00:23:30, 04 Nov.
( 132.980000) PPP IPCP Send Configuration Request
00:23:30, 04 Nov.
( 132.960000) PPP IPCP Receive Configuration NAK
00:23:30, 04 Nov.
( 132.960000) PPP IPCP Send Configuration ACK
00:23:30, 04 Nov.
( 132.960000) PPP IPCP Receive Configuration Request
00:23:30, 04 Nov.
( 132.280000) PPP IPCP Send Configuration Request
00:23:29, 04 Nov.
( 131.270000) PPPoE is up -​ Down Rate=55000Kbps, Up Rate=9999Kbps; SNR Margin Down=7.8dB, Up=22.3dB
00:23:29, 04 Nov.
( 131.250000) CHAP authentication successful
00:23:28, 04 Nov.
( 130.880000) Lease for IP 192.168.1.84 renewed by host DrewRosies-​iPad (MAC 54:ae:27:45:e5:ea). Lease duration: 1440 min
00:23:28, 04 Nov.
( 130.800000) Lease requested
00:23:28, 04 Nov.
( 130.130000) CHAP Receive Challenge
00:23:28, 04 Nov.
( 130.130000) Starting CHAP authentication with peer
00:23:28, 04 Nov.
( 130.130000) PPP LCP Receive Configuration ACK
00:23:27, 04 Nov.
( 130.000000) PPP LCP Send Configuration Request
00:23:27, 04 Nov.
( 130.000000) PPP LCP Receive Configuration Reject
00:23:27, 04 Nov.
( 129.880000) PPP LCP Send Configuration ACK
00:23:27, 04 Nov.
( 129.870000) PPP LCP Receive Configuration Request
00:23:27, 04 Nov.
( 129.870000) PPP LCP Send Configuration Request
00:23:27, 04 Nov.
( 129.130000) Lease for IP 192.168.1.86 renewed by host iPhone (MAC b8:53:ac:55:f8:d5). Lease duration: 1440 min
00:23:27, 04 Nov.
( 129.130000) Device connected: Hostname: iPhone IP: 192.168.1.86 MAC: b8:53:ac:55:f8:d5 Lease time: 1440 min. Link rate: 70.0 Mbps
00:23:27, 04 Nov.
( 129.060000) Lease requested
00:23:27, 04 Nov.
00:23:15, 04 Nov.
ath00: STA b8:53:ac:55:f8:d5 IEEE 802.11: Client associated
00:22:40, 04 Nov.
( 82.900000) Host iPad-​2 (MAC cc:78:5f:f2:86:c1) using IP 192.168.1.76 detected on interface ath10, port -​1
00:22:38, 04 Nov.
( 80.420000) PTM over DSL is up
00:22:35, 04 Nov.
( 77.600000) CWMP: session closed due to error: Could not resolve host
00:22:35, 04 Nov.
( 77.580000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
00:22:35, 04 Nov.
( 77.570000) CWMP: Session start now. Event code(s): '1 BOOT,M Reboot,4 VALUE CHANGE'
00:22:35, 04 Nov.
ath10: STA cc:78:5f:f2:86:c1 IEEE 802.11: Client associated
00:22:31, 04 Nov.
( 73.570000) Lease for IP 192.168.1.76 renewed by host iPad-​2 (MAC cc:78:5f:f2:86:c1). Lease duration: 1440 min
00:22:31, 04 Nov.
( 73.570000) Device connected: Hostname: iPad-​2 IP: 192.168.1.76 MAC: cc:78:5f:f2:86:c1 Lease time: 1440 min. Link rate: 52.8 Mbps
00:22:31, 04 Nov.
( 73.490000) Lease requested
00:22:31, 04 Nov.
ath00: STA cc:78:5f:f2:86:c1 IEEE 802.11: Client associated
00:22:15, 04 Nov.
( 57.150000) Lease for IP 192.168.1.68 renewed by host amazon-​e29944717 (MAC 44:65:0d:18:ae:d9). Lease duration: 1440 min
00:22:15, 04 Nov.
( 57.150000) Device connected: Hostname: amazon-​e29944717 IP: 192.168.1.68 MAC: 44:65:0d:18:ae:d9 Lease time: 1440 min. Link rate: 39.0 Mbps
00:22:14, 04 Nov.
( 56.950000) Lease requested
00:22:13, 04 Nov.
( 55.910000) Lease for IP 192.168.1.71 renewed by host Unknown-​bc-​30-​7d-​ac-​c8-​08 (MAC bc:30:7d:ac:c8:08). Lease duration: 1440 min
00:22:13, 04 Nov.
( 55.910000) Device connected: Hostname: Unknown-​bc-​30-​7d-​ac-​c8-​08 IP: 192.168.1.71 MAC: bc:30:7d:ac:c8:08 Lease time: 1440 min. Link rate: 6.0 Mbps
00:22:13, 04 Nov.
( 55.810000) Lease requested
00:22:13, 04 Nov.
ath00: STA 44:65:0d:18:ae:d9 IEEE 802.11: Client associated
00:22:08, 04 Nov.
( 50.540000) Lease for IP 192.168.1.64 renewed by host PS4-​b0-​05-​94-​4d-​68-​27 (MAC b0:05:94:4d:68:27). Lease duration: 1440 min
00:22:08, 04 Nov.
( 50.530000) Device connected: Hostname: PS4-​b0-​05-​94-​4d-​68-​27 IP: 192.168.1.64 MAC: b0:05:94:4d:68:27 Lease time: 1440 min. Link rate: 105.6 Mbps
00:22:08, 04 Nov.
( 50.360000) Lease requested
00:22:07, 04 Nov.
ath10: STA bc:30:7d:ac:c8:08 IEEE 802.11: Client associated
00:22:06, 04 Nov.
( 48.610000) Lease for IP 192.168.1.66 renewed by host Chromecast (MAC 6c:ad:f8:87:42:8f). Lease duration: 1440 min
00:22:06, 04 Nov.
( 48.610000) Device connected: Hostname: Chromecast IP: 192.168.1.66 MAC: 6c:ad:f8:87:42:8f Lease time: 1440 min. Link rate: 52.7 Mbps
00:22:06, 04 Nov.
( 48.440000) Lease requested
00:22:05, 04 Nov.
( 47.260000) CWMP: session closed due to error: Could not resolve host
00:22:05, 04 Nov.
( 47.120000) Device disconnected: Hostname: Unknown-​bc-​30-​7d-​ac-​c8-​08 IP: 192.168.1.71 MAC: bc:30:7d:ac:c8:08
00:22:05, 04 Nov.
( 47.120000) Device disconnected: Hostname: Rosies-​iPhone IP: 192.168.1.87 MAC: b8:53:ac:d6:e1:c1
00:22:05, 04 Nov.
ath00: STA b8:53:ac:d6:e1:c1 IEEE 802.11: Client disassociated
00:22:05, 04 Nov.
00:22:05, 04 Nov.
00:22:05, 04 Nov.
ath10: STA bc:30:7d:ac:c8:08 IEEE 802.11: Client disassociated
00:22:05, 04 Nov.
ath00: STA b8:53:ac:d6:e1:c1 IEEE 802.11: Client associated
00:22:04, 04 Nov.
00:21:59, 04 Nov.
STP Alert: Port eth0 leaving blocking state.
00:21:55, 04 Nov.
( 37.300000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
00:21:55, 04 Nov.
( 37.290000) CWMP: Session start now. Event code(s): '1 BOOT,M Reboot,4 VALUE CHANGE'
00:21:54, 04 Nov.
( 36.670000) CWMP: Initializing transaction for event code 1 BOOT
00:21:53, 04 Nov.
( 35.260000) WiFi auto selected channel 44
00:21:53, 04 Nov.
( 35.260000) 36-​94::40-​95::44-​94::48-​94::52-​94::56-​92::60-​92::64-​93::100-​93::104-​92::108-​94::112-​94::116-​95::120-​95::124-​96::128-​97
00:21:53, 04 Nov.
( 35.250000) 5 GHz Wireless: Rescan, Reason: 'Power-​up'
00:21:53, 04 Nov.
( 35.250000) WiFi auto selected channel 1
00:21:53, 04 Nov.
( 35.250000) 1-​96::2-​96::3-​96::4-​95::5-​96::6-​97::7-​97::8-​97::9-​98::10-​97::11-​98::12-​97::13-​97
00:21:53, 04 Nov.
( 35.240000) 2.4 GHz Wireless: Rescan, Reason: 'Power-​up'
00:21:53, 04 Nov.
( 35.240000) Wire Lan Port 3 up
00:21:52, 04 Nov.
( 34.470000) WAN Auto-​sensing running.
00:21:48, 04 Nov.
( 30.180000) System up, firmware version: 4.7.5.1.83.8.236.1.2 (Type A)
00:21:43, 04 Nov.
( 26.030000) WPA2 mode selected
00:21:43, 04 Nov.
( 26.030000) WPS enabled
00:21:42, 04 Nov.
( 24.240000) WPA2 mode selected
00:21:42, 04 Nov.
( 24.240000) WPS enabled
00:21:33, 04 Nov.
( 15.860000) System start TR069
00:20:43, 04 Nov.
(141171.900000) PPP LCP Send Termination Request [User request]
00:20:42, 04 Nov.
(141170.600000) CWMP: session completed successfully
00:20:42, 04 Nov.
(141170.600000) The system is going DOWN for reboot.
00:20:40, 04 Nov.
(141168.150000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
00:20:37, 04 Nov.
(141165.250000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
Bottom of Form
00:20:37, 04 Nov.
(141165.240000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE'
00:20:36, 04 Nov.
(141164.710000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
drewb
Message 16 of 31
Both disconnections (posted above) since Engineer visit seem to be related to remote management.   Is this an issue with the hub?  Firmware seems to be up to date.
Moderator
Moderator
Message 17 of 31
@drewb it's likely DLM is recalculating your profile as lines are often placed back in a 10 day training period after a repair has been made. Can you post your router stats instead of the log?
drewb
Message 18 of 31
5. DSL uptime:0 days, 14:08:10
6. Data rate:9999 / 54932
7. Maximum data rate:27971 / 73659
8. Noise margin:22.8 / 11.2
9. Line attenuation:19.7 / 16.0
10. Signal attenuation:19.7 / 16.1
11. Data sent/received:400.1 MB / 13.2 GB
13. BT Wi-fi:Yes
drewb
Message 19 of 31
Unfortunately, this has not been resolved & my synce speed has gone down by 10Mbps over 7-10 days and is below the expeceted guaranteed minimum of 49Mbps.
Information for Helpdesk agents
When contacting the BT Broadband helpdesk, the agent might ask you for details about your BT Home Hub. This page contains all of the information they are likely to request.
5. DSL uptime:0 days, 04:36:36
6. Data rate:8084 / 42050
7. Maximum data rate:28687 / 73733
8. Noise margin:20.4 / 14.3
11. Data sent/received:62.0 MB / 526.6 MB
13. BT Wi-fi:Yes
Sage
Sage
Message 20 of 31
Have you done a quiet line test? 17070 option2.
