smarshallsay
Message 1 of 3
Frequent disconnects on otherwise stable line
Regular disconnects on otherwise fast and stable line. Thanks for any assistance!
My postcode is London N7 - i connect with maximum speed to the 76Mb Infinity and latency etc is very stable and low. However multiple times a day, most noticeably in the evening around midnight the router will disconnect.
Here is an example logs:
TR069:
18:07:48, 30 May.	( 207.450000) CWMP: session completed successfully
18:07:47, 30 May.	( 206.940000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
18:07:46, 30 May.	( 205.200000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
18:07:46, 30 May.	( 205.200000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE'
18:07:45, 30 May.	( 204.720000) CWMP: session completed successfully
18:07:43, 30 May.	( 202.700000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
18:07:41, 30 May.	( 200.440000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
18:07:41, 30 May.	( 200.350000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
18:07:41, 30 May.	( 200.340000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE'
18:07:40, 30 May.	( 199.880000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
18:07:36, 30 May.	( 196.020000) CWMP: session completed successfully
18:07:36, 30 May.	( 195.370000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
18:07:33, 30 May.	( 192.580000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
18:07:33, 30 May.	( 192.570000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
18:07:03, 30 May.	( 162.100000) CWMP: session closed due to error: WGET TLS error
18:06:38, 30 May.	( 152.930000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
18:06:38, 30 May.	( 152.920000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
18:05:54, 30 May.	( 108.670000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
18:05:26, 30 May.	( 80.520000) CWMP: session closed due to error: No response
18:05:25, 30 May.	( 80.460000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
18:05:25, 30 May.	( 80.450000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
18:04:55, 30 May.	( 50.100000) CWMP: session closed due to error: No response
18:04:47, 30 May.	( 42.270000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
18:04:47, 30 May.	( 42.260000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
18:04:47, 30 May.	( 41.690000) CWMP: Initializing transaction for event code 1 BOOT
18:03:48, 30 May.	(1222707.760000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
18:03:48, 30 May.	(1222707.760000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
18:03:47, 30 May.	(1222707.280000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
23:20:49, 29 May.	(1155331.310000) CWMP: session completed successfully
23:20:49, 29 May.	(1155331.110000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
23:20:48, 29 May.	(1155329.740000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
23:20:48, 29 May.	(1155329.740000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE'
23:20:47, 29 May.	(1155329.220000) CWMP: session completed successfully
23:20:47, 29 May.	(1155328.590000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
23:20:46, 29 May.	(1155327.510000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
23:20:46, 29 May.	(1155327.480000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
23:20:46, 29 May.	(1155327.480000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE'
23:20:45, 29 May.	(1155326.980000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
23:20:42, 29 May.	(1155324.270000) CWMP: session completed successfully
23:20:42, 29 May.	(1155324.060000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
23:20:41, 29 May.	(1155322.350000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
23:20:40, 29 May.	(1155322.340000) CWMP: Session start now. Event code(s): '2 PERIODIC,4 VALUE CHANGE'
23:20:40, 29 May.	(1155321.850000) CWMP: Initializing transaction for event code 2 PERIODIC
23:45:52, 28 May.	(1070435.670000) CWMP: session completed successfully
23:45:52, 28 May.	(1070435.480000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
23:45:41, 28 May.	(1070424.740000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
23:45:41, 28 May.	(1070424.730000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
23:44:39, 28 May.	(1070363.260000) CWMP: session closed due to error: No response
23:44:39, 28 May.	(1070362.750000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
23:44:39, 28 May.	(1070362.740000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
23:44:08, 28 May.	(1070332.270000) CWMP: session closed due to error: No response
23:44:08, 28 May.	(1070332.240000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
23:44:08, 28 May.	(1070332.240000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
23:44:08, 28 May.	(1070331.760000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
23:20:48, 28 May.	(1068931.890000) CWMP: session completed successfully
23:20:48, 28 May.	(1068931.720000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
23:20:47, 28 May.	(1068930.710000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
23:20:47, 28 May.	(1068930.700000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE'
23:20:46, 28 May.	(1068930.200000) CWMP: session completed successfully
23:20:46, 28 May.	(1068929.590000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
23:20:45, 28 May.	(1068928.590000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
23:20:45, 28 May.	(1068928.560000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
23:20:45, 28 May.	(1068928.550000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE'
23:20:44, 28 May.	(1068928.060000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
23:20:42, 28 May.	(1068926.260000) CWMP: session completed successfully
23:20:42, 28 May.	(1068926.090000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
23:20:40, 28 May.	(1068923.840000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
23:20:40, 28 May.	(1068923.830000) CWMP: Session start now. Event code(s): '2 PERIODIC,4 VALUE CHANGE'
23:20:39, 28 May.	(1068923.350000) CWMP: Initializing transaction for event code 2 PERIODIC
23:20:50, 27 May.	(982535.780000) CWMP: session completed successfully
23:20:50, 27 May.	(982535.620000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
23:20:49, 27 May.	(982534.620000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
23:20:49, 27 May.	(982534.610000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE'
23:20:48, 27 May.	(982534.120000) CWMP: session completed successfully
23:20:47, 27 May.	(982533.280000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
23:20:46, 27 May.	(982531.630000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
23:20:45, 27 May.	(982531.370000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
23:20:45, 27 May.	(982531.360000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE'
23:20:45, 27 May.	(982530.880000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
23:20:43, 27 May.	(982529.120000) CWMP: session completed successfully
23:20:43, 27 May.	(982528.950000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
23:20:41, 27 May.	(982527.330000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
23:20:41, 27 May.	(982527.330000) CWMP: Session start now. Event code(s): '2 PERIODIC,4 VALUE CHANGE'
23:20:41, 27 May.	(982526.840000) CWMP: Initializing transaction for event code 2 PERIODIC
23:20:48, 26 May.	(896137.030000) CWMP: session completed successfully
23:20:48, 26 May.	(896136.870000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
23:20:47, 26 May.	(896135.550000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
23:20:47, 26 May.	(896135.540000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE'
23:20:46, 26 May.	(896135.060000) CWMP: session completed successfully
23:20:45, 26 May.	(896134.120000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
23:20:44, 26 May.	(896132.840000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
23:20:44, 26 May.	(896132.810000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
23:20:44, 26 May.	(896132.810000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE'
23:20:43, 26 May.	(896132.330000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
23:20:42, 26 May.	(896130.710000) CWMP: session completed successfully
23:20:42, 26 May.	(896130.540000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
23:20:40, 26 May.	(896128.830000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
23:20:40, 26 May.	(896128.820000) CWMP: Session start now. Event code(s): '2 PERIODIC,4 VALUE CHANGE'
23:20:39, 26 May.	(896128.350000) CWMP: Initializing transaction for event code 2 PERIODIC
23:20:49, 25 May.	(809739.820000) CWMP: session completed successfully
WAN:
18:06:36, 30 May.	( 150.560000) WAN operating mode is VDSL
18:06:36, 30 May.	( 150.550000) Last WAN operating mode was VDSL
18:06:34, 30 May.	( 148.880000) PPP IPCP Receive Configuration ACK
18:06:34, 30 May.	( 148.730000) PPP IPCP Send Configuration Request
18:06:34, 30 May.	( 148.730000) PPP IPCP Receive Configuration NAK
18:06:34, 30 May.	( 148.730000) PPP IPCP Send Configuration ACK
18:06:34, 30 May.	( 148.730000) PPP IPCP Receive Configuration Request
18:06:34, 30 May.	( 148.520000) PPP IPCP Send Configuration Request
18:06:32, 30 May.	( 147.160000) PPPoE is up -​ Down Rate=79906000Kbps, Up Rate=19999000Kbps; SNR Margin Down=11.5dB, Up=15.5dB
18:06:32, 30 May.	( 147.150000) CHAP authentication successful
18:06:32, 30 May.	( 147.000000) CHAP Receive Challenge
18:06:32, 30 May.	( 147.000000) Starting CHAP authentication with peer
18:06:32, 30 May.	( 147.000000) PPP LCP Receive Configuration ACK
18:06:32, 30 May.	( 146.990000) PPP LCP Send Configuration Request
18:06:32, 30 May.	( 146.990000) PPP LCP Receive Configuration Reject
18:06:32, 30 May.	( 146.870000) PPP LCP Send Configuration ACK
18:06:32, 30 May.	( 146.870000) PPP LCP Receive Configuration Request
18:06:32, 30 May.	( 146.870000) PPP LCP Send Configuration Request
18:05:41, 30 May.	( 95.590000) PTM over DSL is up
18:04:43, 30 May.	( 38.240000) WAN Auto-​sensing running.
18:03:51, 30 May.	(1222711.370000) PPP LCP Send Termination Request [User request]
23:45:38, 28 May.	(1070421.760000) WAN operating mode is VDSL
23:45:38, 28 May.	(1070421.750000) Last WAN operating mode was VDSL
23:45:36, 28 May.	(1070419.670000) PPP IPCP Receive Configuration ACK
23:45:36, 28 May.	(1070419.660000) PPP IPCP Send Configuration Request
23:45:36, 28 May.	(1070419.660000) PPP IPCP Receive Configuration NAK
23:45:36, 28 May.	(1070419.660000) PPP IPCP Send Configuration ACK
23:45:36, 28 May.	(1070419.660000) PPP IPCP Receive Configuration Request
23:45:36, 28 May.	(1070419.650000) PPP IPCP Send Configuration Request
23:45:34, 28 May.	(1070418.100000) PPPoE is up -​ Down Rate=79906000Kbps, Up Rate=19999000Kbps; SNR Margin Down=11.4dB, Up=15.5dB
23:45:34, 28 May.	(1070418.090000) CHAP authentication successful
23:45:34, 28 May.	(1070417.980000) CHAP Receive Challenge
23:45:34, 28 May.	(1070417.980000) Starting CHAP authentication with peer
23:45:34, 28 May.	(1070417.980000) PPP LCP Receive Configuration ACK
23:45:34, 28 May.	(1070417.980000) PPP LCP Send Configuration Request
23:45:34, 28 May.	(1070417.980000) PPP LCP Receive Configuration Reject
23:45:34, 28 May.	(1070417.970000) PPP LCP Send Configuration ACK
23:45:34, 28 May.	(1070417.970000) PPP LCP Receive Configuration Request
23:45:34, 28 May.	(1070417.970000) PPP LCP Send Configuration Request
23:44:43, 28 May.	(1070367.250000) PTM over DSL is up
23:44:06, 28 May.	(1070329.580000) PTM over DSL is down after 7202 minutes uptime
23:44:06, 28 May.	(1070329.570000) PPPoE is down after 7201 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
23:44:02, 28 May.	(1070326.340000) PPP LCP Send Termination Request [User request]
23:42:41, 23 May.	(638256.170000) WAN operating mode is VDSL
23:42:41, 23 May.	(638256.170000) Last WAN operating mode was VDSL
23:42:39, 23 May.	(638254.330000) PPP IPCP Receive Configuration ACK
23:42:39, 23 May.	(638254.320000) PPP IPCP Send Configuration Request
23:42:39, 23 May.	(638254.320000) PPP IPCP Receive Configuration NAK
23:42:39, 23 May.	(638254.310000) PPP IPCP Send Configuration ACK
23:42:39, 23 May.	(638254.310000) PPP IPCP Receive Configuration Request
23:42:39, 23 May.	(638254.310000) PPP IPCP Send Configuration Request
23:42:38, 23 May.	(638252.820000) PPPoE is up -​ Down Rate=79906000Kbps, Up Rate=19999000Kbps; SNR Margin Down=11.4dB, Up=15.6dB
23:42:38, 23 May.	(638252.810000) CHAP authentication successful
23:42:38, 23 May.	(638252.690000) CHAP Receive Challenge
23:42:38, 23 May.	(638252.690000) Starting CHAP authentication with peer
23:42:38, 23 May.	(638252.690000) PPP LCP Receive Configuration ACK
23:42:38, 23 May.	(638252.690000) PPP LCP Send Configuration Request
23:42:38, 23 May.	(638252.690000) PPP LCP Receive Configuration Reject
23:42:38, 23 May.	(638252.680000) PPP LCP Send Configuration ACK
23:42:38, 23 May.	(638252.680000) PPP LCP Receive Configuration Request
23:42:38, 23 May.	(638252.680000) PPP LCP Send Configuration Request
23:41:47, 23 May.	(638202.260000) PTM over DSL is up
23:41:10, 23 May.	(638164.490000) PTM over DSL is down after 7198 minutes uptime
23:41:10, 23 May.	(638164.490000) PPPoE is down after 7197 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
23:41:06, 23 May.	(638161.340000) PPP LCP Send Termination Request [User request]
23:43:50, 18 May.	(206334.490000) WAN operating mode is VDSL
23:43:50, 18 May.	(206334.490000) Last WAN operating mode was VDSL
23:43:48, 18 May.	(206332.770000) PPP IPCP Receive Configuration ACK
23:43:48, 18 May.	(206332.760000) PPP IPCP Send Configuration Request
23:43:48, 18 May.	(206332.760000) PPP IPCP Receive Configuration NAK
23:43:48, 18 May.	(206332.760000) PPP IPCP Send Configuration ACK
23:43:48, 18 May.	(206332.750000) PPP IPCP Receive Configuration Request
23:43:48, 18 May.	(206332.730000) PPP IPCP Send Configuration Request
23:43:46, 18 May.	(206331.380000) PPPoE is up -​ Down Rate=79906000Kbps, Up Rate=19999000Kbps; SNR Margin Down=11.4dB, Up=15.5dB
23:43:46, 18 May.	(206331.370000) CHAP authentication successful
23:43:46, 18 May.	(206331.190000) CHAP Receive Challenge
23:43:46, 18 May.	(206331.190000) Starting CHAP authentication with peer
23:43:46, 18 May.	(206331.190000) PPP LCP Receive Configuration ACK
23:43:46, 18 May.	(206331.180000) PPP LCP Send Configuration Request
23:43:46, 18 May.	(206331.180000) PPP LCP Receive Configuration Reject
23:43:46, 18 May.	(206331.180000) PPP LCP Send Configuration ACK
23:43:46, 18 May.	(206331.180000) PPP LCP Receive Configuration Request
23:42:56, 18 May.	(206281.040000) PTM over DSL is up
23:42:19, 18 May.	(206244.080000) PTM over DSL is down after 3435 minutes uptime
23:42:19, 18 May.	(206244.070000) PPPoE is down after 3434 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
23:42:16, 18 May.	(206241.070000) PPP LCP Send Termination Request [User request]
14:27:07, 16 May.	( 149.990000) WAN operating mode is VDSL
14:27:07, 16 May.	( 149.990000) Last WAN operating mode was VDSL
14:27:06, 16 May.	( 148.460000) PPP IPCP Receive Configuration ACK
14:27:06, 16 May.	( 148.460000) PPP IPCP Send Configuration Request
14:27:06, 16 May.	( 148.450000) PPP IPCP Receive Configuration NAK
14:27:05, 16 May.	( 148.450000) PPP IPCP Send Configuration ACK
14:27:05, 16 May.	( 148.450000) PPP IPCP Receive Configuration Request
14:27:05, 16 May.	( 148.450000) PPP IPCP Send Configuration Request
14:27:04, 16 May.	( 147.120000) PPPoE is up -​ Down Rate=79906000Kbps, Up Rate=19999000Kbps; SNR Margin Down=11.4dB, Up=15.6dB
14:27:04, 16 May.	( 147.110000) CHAP authentication successful
14:27:04, 16 May.	( 147.050000) CHAP Receive Challenge
14:27:04, 16 May.	( 147.040000) Starting CHAP authentication with peer
14:27:04, 16 May.	( 147.040000) PPP LCP Receive Configuration ACK
2 REPLIES 2
smarshallsay
Message 2 of 3
Re: Frequent disconnects on otherwise stable line
System:
18:03:50, 30 May. (1222709.720000) The system is going DOWN for reboot.
18:03:50, 30 May. (1222709.720000) OpenRG is going for reboot by IPC command
18:03:45, 30 May. (1222704.720000) OpenRG will go down for reboot in 5 seconds
14:24:19, 16 May. (474942.570000) The system is going DOWN for reboot.
02:28:53, 11 May. STP Alert: Port eth0 leaving blocking state.
18:22:21, 05 May. (1211189.280000) The system is going DOWN for reboot.
18:22:21, 05 May. (1211189.280000) OpenRG is going for reboot by IPC command
18:22:16, 05 May. (1211184.280000) OpenRG will go down for reboot in 5 seconds
17:54:51, 21 Apr. (66832.980000) The system is going DOWN for reboot.
20:51:57, 27 Mar. (84852.830000) The system is going DOWN for reboot.
16:10:34, 21 Mar. STP Alert: Port eth0 leaving blocking state.
04:03:40, 14 Mar. (63102.960000) The system is going DOWN for reboot.
10:31:25, 13 Mar. (1211008.180000) The system is going DOWN for reboot.
10:31:25, 13 Mar. (1211008.180000) OpenRG is going for reboot by IPC command
10:31:20, 13 Mar. (1211003.180000) OpenRG will go down for reboot in 5 seconds
11:07:58, 27 Feb. STP Alert: Port eth0 leaving blocking state.
01:01:11, 07 May. ( 86.500000) The system is going DOWN for reboot.
01:07:01, 13 Feb. STP Alert: Port eth0 leaving blocking state.
00:05:59, 13 Feb. (1211038.410000) The system is going DOWN for reboot.
00:05:59, 13 Feb. (1211038.410000) OpenRG is going for reboot by IPC command
00:05:54, 13 Feb. (1211033.410000) OpenRG will go down for reboot in 5 seconds
00:42:05, 30 Jan. STP Alert: Port eth0 leaving blocking state.
23:41:02, 29 Jan. (1212607.080000) The system is going DOWN for reboot.
23:41:02, 29 Jan. (1212607.080000) OpenRG is going for reboot by IPC command
23:40:57, 29 Jan. (1212602.080000) OpenRG will go down for reboot in 5 seconds
23:50:59, 15 Jan. STP Alert: Port eth0 leaving blocking state.
01:00:47, 07 May. ( 63.140000) The system is going DOWN for reboot.
01:02:31, 07 May. ( 167.160000) The system is going DOWN for reboot.
01:00:29, 07 May. STP Alert: Port eth0 leaving blocking state.
22:10:17, 02 Jan. (435796.970000) The system is going DOWN for reboot.
22:07:20, 28 Dec. STP Alert: Port eth0 leaving blocking state.
01:01:25, 07 May. ( 101.200000) The system is going DOWN for reboot.
01:12:01, 28 Dec. ( 191.030000) The system is going DOWN for reboot.
02:09:20, 28 Dec. STP Alert: Port eth0 leaving blocking state.
21:41:38, 16 Dec. (1211128.300000) The system is going DOWN for reboot.
21:41:38, 16 Dec. (1211128.300000) OpenRG is going for reboot by IPC command
21:41:33, 16 Dec. (1211123.200000) OpenRG will go down for reboot in 5 seconds
21:19:39, 23 Nov. STP Alert: Port eth0 leaving blocking state.
01:56:55, 16 Nov. (1215432.010000) The system is going DOWN for reboot.
01:56:55, 16 Nov. (1215432.010000) OpenRG is going for reboot by IPC command
01:56:50, 16 Nov. (1215427.010000) OpenRG will go down for reboot in 5 seconds
01:19:46, 02 Nov. STP Alert: Port eth0 leaving blocking state.
00:18:46, 02 Nov. (1224049.190000) The system is going DOWN for reboot.
00:18:46, 02 Nov. (1224049.190000) OpenRG is going for reboot by IPC command
00:18:41, 02 Nov. (1224044.190000) OpenRG will go down for reboot in 5 seconds
21:17:58, 18 Oct. STP Alert: Port eth0 leaving blocking state.
01:57:11, 18 Oct. (1235350.060000) The system is going DOWN for reboot.
01:57:11, 18 Oct. (1235350.060000) OpenRG is going for reboot by IPC command
01:57:06, 18 Oct. (1235345.060000) OpenRG will go down for reboot in 5 seconds
18:48:01, 03 Oct. STP Alert: Port eth0 leaving blocking state.
08:53:25, 26 Sep. (510690.980000) The system is going DOWN for reboot.
11:01:10, 20 Sep. (1215652.450000) The system is going DOWN for reboot.
11:01:10, 20 Sep. (1215652.450000) OpenRG is going for reboot by IPC command
11:01:05, 20 Sep. (1215647.450000) OpenRG will go down for reboot in 5 seconds
09:20:19, 06 Sep. STP Alert: Port eth0 leaving blocking state.
19:07:56, 04 Sep. (1210947.700000) The system is going DOWN for reboot.
19:07:56, 04 Sep. (1210947.700000) OpenRG is going for reboot by IPC command
19:07:51, 04 Sep. (1210942.700000) OpenRG will go down for reboot in 5 seconds
18:44:33, 21 Aug. (247265.540000) The system is going DOWN for reboot.
22:02:54, 18 Aug. (1222595.800000) The system is going DOWN for reboot.
22:02:54, 18 Aug. (1222595.800000) OpenRG is going for reboot by IPC command
22:02:49, 18 Aug. (1222590.800000) OpenRG will go down for reboot in 5 seconds
18:26:20, 04 Aug. STP Alert: Port eth0 leaving blocking state.
18:25:25, 04 Aug. (1241096.260000) The system is going DOWN for reboot.
18:25:25, 04 Aug. (1241096.260000) OpenRG is going for reboot by IPC command
18:25:20, 04 Aug. (1241091.260000) OpenRG will go down for reboot in 5 seconds
09:40:29, 21 Jul. STP Alert: Port eth0 leaving blocking state.
09:39:33, 21 Jul. (241158.050000) The system is going DOWN for reboot.
14:40:34, 18 Jul. STP Alert: Port eth0 leaving blocking state.
14:39:42, 18 Jul. (1212990.080000) The system is going DOWN for reboot.
14:39:42, 18 Jul. (1212990.080000) OpenRG is going for reboot by IPC command
14:39:37, 18 Jul. (1212985.080000) OpenRG will go down for reboot in 5 seconds
20:17:15, 30 Jun. STP Alert: Port eth0 leaving blocking state.
00:52:18, 22 Jun. (1211241.820000) The system is going DOWN for reboot.
00:52:18, 22 Jun. (1211241.820000) OpenRG is going for reboot by IPC command
00:52:13, 22 Jun. (1211236.820000) OpenRG will go down for reboot in 5 seconds
00:25:00, 08 Jun. STP Alert: Port eth0 leaving blocking state.
00:22:06, 08 Jun. (536586.160000) The system is going DOWN for reboot.
19:18:22, 01 Jun. (1212757.180000) The system is going DOWN for reboot.
19:18:22, 01 Jun. (1212757.180000) OpenRG is going for reboot by IPC command
19:18:17, 01 Jun. (1212752.180000) OpenRG will go down for reboot in 5 seconds
18:25:47, 18 May. STP Alert: Port eth0 leaving blocking state.
18:24:52, 18 May. (1230239.790000) The system is going DOWN for reboot.
18:24:52, 18 May. (1230239.790000) OpenRG is going for reboot by IPC command
18:24:47, 18 May. (1230234.790000) OpenRG will go down for reboot in 5 seconds
09:32:38, 03 May. STP Alert: Port eth0 leaving blocking state.
smarshallsay
Message 3 of 3
bump
