Message 11 of 16
Re: Fresh 900 Meg install
There are no other settings you can make.
Message 12 of 16
I’m sure there was about QOS and mu but trying to find out hence posting asking for help
Message 13 of 16
@mrmagicmart
Remember you do not have an exclusive fibre connection.
Speed will vary as you are sharing a 2.5Gb fibre connection with 31 other users, so you will only get the full speed if less customers are using their connection.
Message 14 of 16
Try disabling any QoS settings and look for any hardware acceleration options - sometimes called CTF on Asus routers.  Also worth trying a factory reset.
____________________________________________
BT FTTP 500/75 + pfSense + 4 x UniFi Wifi 6 Pro
Message 15 of 16
I would also make sure that any wireless adapter on the PC/Laptop is disabled as some default to using wireless even with an ethernet cable connected.
Also ensure there is nothing on the device using bandwidth (eg One Drive)
Message 16 of 16
Hi I thought it was a 32 sasa but only split 30 ways ? Also 400 meg drop at 12 pm  seems not right to me as it’s quite then compared to say 6 pm, I’m also the only one on my road on that cbt
