Message 11 of 13
Re: Fttp OTP connection
@dqj999
From the initial post there is no Ethernet switch just a new Build with the Ethernet panel installed when built and cables running from panel to the various locations within the home
Message 12 of 13
Re: Fttp ONT connection
Hi there.
Yes that is correct. The house cabling ( previously installed) comes to a cupboard, but is not connected to a network switch.
I guess I am trying to ask if the ONT to WAN connection on a BT router has different wiring to standard 5e Lan cabling in the house ? Do I need to change the connector wiring or rewire ?
Message 13 of 13
See message 6, the sockets need to be fully wired to GbE standard.
