pbwpu
Message 1 of 7
Fttp speed
My fttp is recently periodically all over the place:
fttp then powerline connection but one day its full speed 80/20 then next as a few mins ago 19/5. (okla speedtest). Service status says everything is fine.
A quick ping test: to the bbc got me results from 29ms to 163ms (base ping is a bit high due to powerline but thats not the 163)
6 REPLIES 6
albertj
Recognised Expert
Message 2 of 7
Re: Fttp speed
Is this the same when not connected via powerline adapters?
They can be fairly unreliable in terms of speed.
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
pippincp
Sage
Message 3 of 7
Re: Fttp speed
@pbwpu At present you do not know if it is your FTTP connection that is a problem or the powerline adapters. The only way to rule out the powerline adapters is to try a direct ethernet connection to the router (providing the router is connected directly to the ONT via ethernet). If the problem then persists by elimination it has to be your FTTP connection.
Until you have done that you will never know.
pbwpu
Message 4 of 7
Re: Fttp speed
Yeah I could run a cat cable to double check. However the powerline is the same device i've used for 2yrs without any issues and the issue is intermittent atm. This morning i'm at 80/20 again.
imjolly
Message 5 of 7
Re: Fttp speed
having used powerline adapters jus because they worked yesterday and for last 2 years does not mean they will work tomorrow - from personal experience they just stop without any warning
pippincp
Sage
Message 6 of 7
Re: Fttp speed
The fact remains until you do it you do not know where the fault lies.
Keep us updated.
DavidM
Moderator
Moderator
Message 7 of 7
Re: Fttp speed
Hi @pbwpu and thanks for posting.
Sorry you're having problems with the connection. @pippincp is correct. The first step would be to try a direct connection without the adaptor for a few days. If the connection remains stable and at full strength you'll know its more than likely the adaptor which is causing the problem. Let us know how you get on.
Cheers
David
