Message 1 of 4
Full Fibre 900 with Halo 3 upgrade
Hi, I am wondering if anyone has upgraded from Full Fibre 900, to Full Fibre 900 with Halo 3 did you receive any new equipment? or additional equipment for the Halo 3 part, not sure what that is, nothing in the new order to suggest any other or new equipment. Thank you.
3 REPLIES 3
Message 2 of 4
Re: Full Fibre 900 with Halo 3 upgrade
with the add on Halo 3 there is no additional equipment sent unless you have loss of connection whereas Halo 3+ you would get additional equipment.  Personally if you have FTTP I don't the need or the extra cost for the Halo 3 add on .  connection on FTTP is far more stable than the previous FTTC
https://www.bt.com/help/broadband/learn-about-broadband/bt-halo/what-is-bt-halo-and-how-can-i-get-it...
Anonymous
Not applicable
Message 3 of 4
If you're in your cooling off period then cancel ASAP.
There is literally no benefit in getting halo
It's actually a massive disadvantage come renewal time
It's a clever wize by  BT to charge you more for less.
Message 4 of 4
Personally, have just moved back to 900 without Halo, I see no difference.
You don’t even own the kit.
