Message 1 of 31
Full Fibre 900 with WiFi - upload capped
Hi
I upgraded to Full Fibre 900 and was getting a good solid 900Mbps down and 100Mbps up. I then went for the Complete WiFi as my Google WiFi didn't seem able to give the throughput. The black discs do seem to be a bit faster than the Google pucks.
I now find my upload speed has dropped to 50Mbps.
I have raised this with BT to be told that it's within the max guaranteed of 10Mbps and I should wait for it to "settle down". However, it seems clear that once WiFi was added to the package the upload has been capped.
How do I get this sorted?
Adam
30 REPLIES 30
Message 2 of 31
Re: Full Fibre 900 with WiFi - upload capped
Are you using the BT smart hub? Were you when you were using the Google products? Some BT smart hubs need a parameter change which occurs after 3/5 days of being connected.
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
Message 3 of 31
there are many posts about up speed 'capped' at 50mb  and you should leave it for 3/4 days as it normally corrects itself without intervention.  if no improvement after 3/4 days post back
Message 4 of 31
Are you using the BT smart hub? - Yes
Were you when you were using the Google products? - Yes
Some BT smart hubs need a parameter change which occurs after 3/5 days of being connected. - oddly, when I first went to 900Mbps there was no delay. Straight to 100Mbps up. When I added WiFi to the package it dropped to 50Mbps.
Message 5 of 31
Okay. Well keep the SH cooking for a few days.
Message 6 of 31
Hi @GDog2 How long have you had your Smart Hub 2 connected for?
Neil
Message 7 of 31
It's been in for several months. Only recently upgraded to 900
Message 8 of 31
Hi @GDog2 When did the upgrade to 900 complete?
Neil
Message 9 of 31
Message 10 of 31
Thanks Dazza - trying them again on 150 🤞🏽
