Anestis
Message 1 of 4
Full Fibre - Replace ONT & Router
Hello,
I recently upgraded to Full Fibre 900 and I've been looking into changing the default router to probably a unifi dream machine pro. My question is can I connect the fibre directly to a compatible sfp+ transceiver or would there be a issue with openreach?
Cheers
3 REPLIES 3
licquorice
Message 2 of 4
Re: Full Fibre - Replace ONT & Router
Not possible, the service is locked to the serial number of the ONT. You can't use your own sfp.
pippincp
Message 3 of 4
You can of course use your own router.
Anestis
Message 4 of 4
Yeah I know. I just wanted to know if they do use the ONT serial or I can use the fibre directly. I'll just use normal wan then
