Message 1 of 5
Full Fibre
Recently upgraded to full fiber Halo 3+ all good except the EE Hybrid wont connect it does pair with router but then gets  the flashing red lights at the  bottom where they should turn blue , have done all tests, BT  support sent second EE router  and 5G Antennas still   same fault ,  also tried at all over the house no luck .
When engineer was attending he did not install EE  Hybrid as there is an issue with them , he informed only install when internet goes down .
Got EE on  my mobile no issues strong signal , at a loss on this one
Graham
4 REPLIES 4
Message 2 of 5
Re: Full Fibre
Openreach Engineers and or their Contractors don’t install the 4G Mini Hub.
Its a BT Product that Openreach have no involvement in.
Message 3 of 5
Re: Full Fibre
Ok fair enough but still have issue as EE router does not connect stuck with the red flashing lights , it seems to be issue all over , even BT support cant resolve for now
Graham
Message 4 of 5
Re: Full Fibre
Technically they should not advertise  unbreakable WIFI as other people  have the same  the fault have no back up if EE router does not work
Graham
Message 5 of 5
Re: Full Fibre
Telling me that does not resolve the issue I have , bottom line there is an issue with the EE Hybrid with red lights flashing , BT now have admitted reluctantly there is an issue
Graham
