Message 11 of 17
Re: Full fibre broadband speed
@licquoricewrote:
@Gorsoftwrote:
Contacted BT.  All their checks suggests the problem is at my end, so to eliminate the possibility of my 5 year old BT modem being the problem, the lovely lady from Belfast agreed to send a replacement upgraded model.
Thanks for all the help.
There is no 'upgraded model'.
He may be sent the latest EE Smarthub.
You will no doubt be asked to return your "old" BT Smarthub. Whwn you send it back make sure you keep a copy of your Proof of Posting and if possible take a photograph of it in case you somehow lose the paper copy.
Message 12 of 17
Possibly, either way the Smart Hub2 is perfectly capable unless faulty so no requirement for an 'upgraded' Hub.
Message 13 of 17
I agree but I think the OP must have a Smarthub and not a Smarthub2 as he stated that his Smarthub did not have a dedicated WAN port and the engineer had to change the setting for port 4.
EDIT: I have just re read what the OP posted and I was mistaken. He did say that he had a Smarthub 2 and not a Smarthub as I have posted.
@chrisjp
 I am aware about the Ethernet port needing changed to WAN if it is not already set as a WAN port but you may be correct about the SM2 not having a dedicated WAN port. I just assumed, possibly incorrectly that this was now the case because of what the engineer had said to the OP.
Message 14 of 17
My SH2 also doesn't have a dedicated WAN port, but in the Hub Manager you can toggle the port between a WAN and a LAN port. That's what the engineer did when he "changed the setting".
I thought all SH2s were like this, but maybe later "upgraded" SH2s do have a dedicated WAN port.
I suspect, though, that the BT agent who claimed to be sending out an "upgraded SH2" was talking the usual nonsense that these woefully badly trained agents do!
Message 15 of 17
In message 5 he says he has SH2.
Message 16 of 17
As stated , if the existing hub were incompatible then a new one would be sent out as part of the upgrade to FTTP , regardless of it being ‘upgraded’ model or not , it’s a reasonable course of action to take as it’s an item to tick off the suspect list, hopefully this will fix the problem, indicating it was faulty rather than incompatible.
FWIW , my relatively new SH2 doesn’t have a WAN port as such , just a switchable one from LAN to WAN and although I don't  have FTTP availability, should I get that upgrade path at some point , I won’t need a replacement router .
Message 17 of 17
I was editing my post while you posted.
