Message 1 of 4
Full fibre in bretton Peterborough
I was just wondering if anybody could help answer a question on wayne, full fiber, we'll be in Bretton pe3 area had a representative knock at my door in January and told me it was gonna be in by February. We're now in June. Add no information at all. Has anybody got a time scale? And when this might be happening
[Mod edit - Full postcode removed, please don't share this in public]
3 REPLIES 3
Message 2 of 4
Re: Full fibre in bretton Peterborough
Only openreach know when and if fibre will be available to you and when likely to happen.  BT have no control over installation of fibre by openreach
try   https://www.openreach.com/broadband-network/fibre-availability
Message 3 of 4
Are you sure it was an Openreach representative and not an Alternative Network, I’ve not heard of Openreach canvassing an area door to door ,there is no  point as they don’t sell services to the public ,  but Alt Nets may do this type of canvassing to gauge the likely take up , they may even take advance ‘pre orders’ , so they can get customers signed up as soon as their network is ready , but in any event, as previously stated , this has nothing to do with BT , even if it were an Openreach person knocking on doors .
being a bit nosy I looked at the general area on street view , this shows property that is of a design built in the 1960’s-1970’s , so the area is almost certainly DIG armoured cables , no duct , these types of areas are by far the most expensive type of area for Openreach to retro build a FTTP network into , and the chances are they won’t treat an area like this as a priority as the cost per tenancy is likely to be way in excess of the allocated budget, for the amount it would cost to serve 50 properties here , they could probably  serve  400 -500 properties in areas  served by poles or  already ducted  areas (housing built 1990’s and onwards) .
If it were a Openreach surveyor ( but they don’t normally knock on doors ) they survey the area and produce a design, irrespective of the cost, they don’t decide which designs are completed , that’s in the main a budgetary decision made by management
Message 4 of 4
Full Fibre is an Alt Net Building their own FTTP Network using PIA.
They’re the Network Provider as well as the CP.
BT/EE don’t, and I seriously doubt ever will use them as a Wholesaler.
