Woodford
Message 1 of 12
Further question on Fibre Broadband Availability (I've read DeanM's comments)
My local exchange (Merthyr Tydfil) and street cabinet have both been fibre enabled for over a month.  BT Openreach and BT Broadband sites both confirm that BT is 'Accepting Orders' but whenever I try to place an order, I'm told that I cannot.
Yesterday I spoke to a BT Openreach Engineer and was told that FTTC had been enabled for over a month and that I should be able to order.
I've tried to discover what the situation is but cannot.  Both BT Openreach and BT Broadband sites steadfastedly refuse to provide information.  Is it not possible for me to speak with someone who is able to tell me what the current situation is?
Steve
11 REPLIES 11
Guru
Guru
Message 2 of 12
Re: Further question on Fibre Broadband Availability (I've read DeanM's comments)
Hi Woodford,
What PCP (cabinet) is it ?
Do you know roughtly how far away you are from the cabinet?
Please can you copy and paste all of the results from http://dslchecher.bt.com/adsl into a post. Though remember to edit out your landline number before pressing post.
If you don't have a BT Wholesale reconisable number then try http://dslchecker.bt.com/adsl/ADSLChecker.AddressOutput
Remember that even if the Merthyr Tydfil exchange is AO for Fibre broadband that your PCP (cabinet) will also need to be upgraded with a FTTC DSLAM cabinet before it may be avaiolable to you. Not all PCPs will be upgraded with a FTTC DSLAM cabinet and it may take some time for Superfast-Cymru to install and activate all DSLAM cabinet, so therefore one area of Merthyr Tydfil  will have fibre broadband before other areas of Merthyr.
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Woodford
Message 3 of 12
Hi,
Firstly thanks for the reply.
The data shown on the links just confirms my present situation ie. Cabinet 24 - I can receive broadband at an indicative speed which is about right.  It's hard to believe that there is no-one at BT with whom I can speak to ascertain if and when I can get Superfast Broadband.  The cabinet is some 300m from my home.
The data you asked for is as follows:
BT BROADBAND AVAILABILITY CHECKER
Telephone Number xxxxxxxxxxx on Exchange MERTHYR TYDFIL is served by Cabinet 24
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date
WBC ADSL 2+Up to 2--1.5 to 4Available
ADSL MaxUp to 1.5--1 to 3.5Available
WBC Fixed Rate2 ----Available
Other Offerings
Copper Multicast------Available
For all ADSL and WBC Fibre to the Cabinet (FTTC) services, the stable line rate will be determined during the first 10 days of service usage.
Throughput/download speeds will be less than line rates and can be affected by a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for Datastream is from 30-Jun-2012; the Formal Retirement date for Datastream is from 30-Jun-2014. The Stop Sale date for IPstream is from 26-Jun-2014; the Formal Retirement date for IPstream is from 30-Jun-2014.
If the End User wishes to migrate from their current Broadband supplier they will need to contact them in the first instance to obtain a MAC (Migrations Authorisation) Code, and then contact their new Broadband supplier to arrange for the service to be migrated.
Note: Please note that postcode and address check results are indicative only. Most accurate results can be obtained from a telephone number check.
Thank you for your interest.
Message 4 of 12
The simple answer to your question is th BT Retail your provider like all other ISP's has no information on the fibre rollout, as the fibre network and its rollout is under Openreach's control and until Openreach release information to providers they like you have to wait the information is treat as business sensitive until cabinets go live
Guru
Guru
Message 5 of 12
Hi again Woodford
As you can see from the list below you PCP (cabinet) is still being Installed/Commissioned with a FTTC DSLAM cabinet under the Superfast Cymru BDUK programme.
You can tweet Superfast cymru via @superfastcymru or email info@superfastcymru.com with your PCP number and exchange to see if there is any updates on the deployment of your DSLAM cabinet
  PCP (Cabinet Number Exchange FTTC Status
CF478LJ 5 MERTHYR TYDFIL Available
CF482TN 14 MERTHYR TYDFIL Available
CF481YA 21 MERTHYR TYDFIL Available
CF479BG 25 MERTHYR TYDFIL Available
CF479BT 26 MERTHYR TYDFIL Available
CF479RF 28 MERTHYR TYDFIL Available
CF479TP 30 MERTHYR TYDFIL Available
CF479TW 31 MERTHYR TYDFIL Available
CF478UX 36 MERTHYR TYDFIL Available
CF470ET 45 MERTHYR TYDFIL Available
CF470BA 46 MERTHYR TYDFIL Available
CF478BG 50 MERTHYR TYDFIL Available
CF481AH 52 MERTHYR TYDFIL Available
CF481HN 57 MERTHYR TYDFIL Available
CF482TN 61 MERTHYR TYDFIL Available
CF481TF 64 MERTHYR TYDFIL Available
CF481DR 65 MERTHYR TYDFIL Available
CF484NU 2 YNYSOWEN  Available
CF484QH 3 YNYSOWEN  Available
CF484EL 4 YNYSOWEN  Available
CF484BZ 5 YNYSOWEN  Available
CF481EX 6 YNYSOWEN  Available
CF484DR 7 YNYSOWEN  Available
CF478RL 1 MERTHYR TYDFIL Still being Installed/Commissioned
CF478LS 2 MERTHYR TYDFIL Still being Installed/Commissioned
CF483LD 4 MERTHYR TYDFIL Still being Installed/Commissioned
CF478YW 6 MERTHYR TYDFIL Still being Installed/Commissioned
CF482PG 7 MERTHYR TYDFIL Still being Installed/Commissioned
CF478LL 8 MERTHYR TYDFIL Still being Installed/Commissioned
CF478HA 9 MERTHYR TYDFIL Still being Installed/Commissioned
CF470SG 10 MERTHYR TYDFIL Still being Installed/Commissioned
CF478RR 11 MERTHYR TYDFIL Still being Installed/Commissioned
CF481SB 12 MERTHYR TYDFIL Still being Installed/Commissioned
CF483DP 13 MERTHYR TYDFIL Still being Installed/Commissioned
CF479DF 15 MERTHYR TYDFIL Still being Installed/Commissioned
CF482DD 16 MERTHYR TYDFIL Still being Installed/Commissioned
CF483PE 17 MERTHYR TYDFIL Still being Installed/Commissioned
CF481PB 18 MERTHYR TYDFIL Still being Installed/Commissioned
CF481TN 19 MERTHYR TYDFIL Still being Installed/Commissioned
CF470PG 20 MERTHYR TYDFIL Still being Installed/Commissioned
CF481LD 22 MERTHYR TYDFIL Still being Installed/Commissioned
CF482NP 23 MERTHYR TYDFIL Still being Installed/Commissioned
CF482EW 24 MERTHYR TYDFIL Still being Installed/Commissioned
CF479RA 27 MERTHYR TYDFIL Still being Installed/Commissioned
CF479EJ 32 MERTHYR TYDFIL Still being Installed/Commissioned
CF479LB 33 MERTHYR TYDFIL Still being Installed/Commissioned
CF482UD 34 MERTHYR TYDFIL Still being Installed/Commissioned
CF479LN 35 MERTHYR TYDFIL Still being Installed/Commissioned
CF470LN 37 MERTHYR TYDFIL Still being Installed/Commissioned
CF482PL 38 MERTHYR TYDFIL Still being Installed/Commissioned
CF470UE 39 MERTHYR TYDFIL Still being Installed/Commissioned
CF470HY 43 MERTHYR TYDFIL Still being Installed/Commissioned
CF470HG 44 MERTHYR TYDFIL Still being Installed/Commissioned
CF478EU 47 MERTHYR TYDFIL Still being Installed/Commissioned
CF478DN 48 MERTHYR TYDFIL Still being Installed/Commissioned
CF481BA 51 MERTHYR TYDFIL Still being Installed/Commissioned
CF483RR 53 MERTHYR TYDFIL Still being Installed/Commissioned
CF483AR 54 MERTHYR TYDFIL Still being Installed/Commissioned
CF483ND 55 MERTHYR TYDFIL Still being Installed/Commissioned
CF478NR 56 MERTHYR TYDFIL Still being Installed/Commissioned
CF479DS 58 MERTHYR TYDFIL Still being Installed/Commissioned
CF482BT 60 MERTHYR TYDFIL Still being Installed/Commissioned
CF481SE 63 MERTHYR TYDFIL Still being Installed/Commissioned
CF484RR 1 YNYSOWEN  Still being Installed/Commissioned
CF484HY 8 YNYSOWEN  Still being Installed/Commissioned
As others have said BT Retail is just an ISP/CP and doesn't have any input or extra info on the deployment of fibre broadband.
Try a Search
Distinguished Guru
Message 6 of 12
@jac_95
Did you get this list from Openreach?
If not, I'll try again 🙂
Woodford
Message 7 of 12
Hi all,
Many thanks for the replies which have been very useful.  I did not receive the list posted by jac which does clearly show the present situation.  After weeks of trying, I did eventually receive a reply from Bt which said that they expected the residential roll-out to be completed by Dec 31st 2914.
What confused the issue was that BT Broadband Engineer said that the relevant cabinet had already been activated over a month ago.
Anyway, I now know a target date and that satisfies my query.
Thanks again.
Steve
Woodford
Message 8 of 12
Correction - 2014 not 2914, although it seems like the latter!!!!!!!!!!!!!!!!
Woodford
Message 9 of 12
Hi again,
Can you please let me know how to access the list you sent on progress regarding commissioning of individual cabinets.  I can't seem to track anything via the BT Openreach site, the email link info@ etc does not work and I just don't understand Twitter.  Apologies for being dense.
Steve
Sage
Sage
Message 10 of 12
Try Superfast Cymru as they have the info.
