Message 11 of 32
Re: G Fast Activationc
There will be a heading G.FAST where FTTPOD is at present and until you see it there and available you cannot order so as already said you need to keep checking
Message 12 of 32
It will look something like this
Message 13 of 32
Many thanks liquorice 👍
Sage
Message 14 of 32
Looking at the OP's original post leads me to suspect an exchange only line. As the OP cannot get VDSL how is he expected to get G.Fast?
Message 15 of 32
Good point, well spotted.
Message 16 of 32
I did ask about FTTP as its showing in the OP checker but was told it's not available...all a bit confusing ☹
Recognised Expert
Message 17 of 32
FTTPod isn’t the same as native FTTP, and it’s only FTTPod available to you.
The odd thing is that VDSL (FTTC) isn’t available to you , but FTTPod is, which suggests you are on a cab that has VDSL but you are too far from it to benefit ( hence it not showing as an option ) so Gfast will not show as an option as again you are too far away from it to benefit, but your ADSL speed is quite good which suggests your total distance , you to cab to to the exchange cannot be too long, yet the distance from the cab to you is too long for VDSL ...very strange
GFast multicast under other services doesn’t mean that Gfast is available to you, as a consumer you cannot purchase ‘multicast’, it’s a service an ISP could use in the distribution of IPTV, so you could be a customer of an ISP that consumes ‘multicast’ in its service to you, the fact that ADSL multicast is also shown as ‘other services’ means that you could have BTTV on ADSL
Message 18 of 32
Did the DSL checker show cab 25 when you entered your phone number (you have chopped off the top of the screenshot) or did you assume you are connected to cab25? If it didn't show a cabinet number you are on an EO line not connected to a cabinet.
Message 19 of 32
Thank you all for your help
Liquorice - when I checked it showed connected to Cabinet 25. Here is a screenshot
Iniltous - what are my options, do I need to speak to Openreach?
Message 20 of 32
How far away are you from cab25 and from the exchange if you know where they are both located.
As @iniltous  says, the figures don't really make much sense. If you are too far from the cab for FTTC I would have thought you were too far away from the exchange (via cab25) for the sort of ADSL speed you are getting.
