NigelB72
Guru
Message 1 of 6
I'm moving to G.Fast on Friday and have just had my SmartHub2 delivered, can I swap the routers now or do I have to wait for G.Fast upgrade to be completed? Taa
5 REPLIES 5
licquorice
Message 2 of 6
Re: G.Fast
You can swap now.
NigelB72
Guru
Message 3 of 6
Re: G.Fast
Cool.. I'll do it in a bit 👍
licquorice
Message 4 of 6
Re: G.Fast
Remember to turn off Smart setup and also be advised you can't split the wifi SSIDs with the SH2.
conrad
Recognised Expert
Message 5 of 6
Re: G.Fast
If you had a calling plan you better check what it has been changed to as they are now different.
NigelB72
Guru
Message 6 of 6
Re: G.Fast
Don't need calling plan as I think I've used the landline once in 5 years and that was only to find my mobile 😂... Plugged a phone in when we moved in and unplugged it within 2 days due to all the telesales calls. Literally getting 10-15 a day
