Message 1 of 2
GFAST Connection 150/250
If I get a 150mb gfast connection will that modem/router work in the extension socket, normally it's recommended to install that into the master socket?
1 REPLY 1
Message 2 of 2
Re: GFAST Connection 150/250
no  you need to connect G.FAST to master socket
