Toddie1982
Message 1 of 2
GFast faceplate and Test Socket
Hi,
I have a question.....
With Gfast and the Gfast master socket faceplace... If I remove the front of the faceplate and plug to test socket, will a normal Filter work or do you need a special gfast one due to higher frequencies?
Stuart
1 REPLY 1
Sage
Sage
Message 2 of 2
Re: GFast faceplate and Test Socket
Normal filter.
