Message 21 of 30
Re: What on earth is going on with connectivity
Hi @coreservers,
Thank you for posting back to update the thread. It's good to see that the speeds have increased after the visit and it sounds like the engineer was very thorough in their investigation.
Please keep an eye on your connection and post back in a few days and let us know how the connection is performing?
Thanks,
Paddy
Message 22 of 30
nope. not fixed.
ok i know im on dlm... but its dropping every 3-4 minutes now. gone from 70mb down to 60 mb. seems that didnt fix it
Message 23 of 30
I had a similar issue which ran off-and-on for about a year.   Every time we had heavy rain within a couple of hours the speed had dropped sometimes from 40+Mb to <10Mb. It would restore on its own about a day after the rain.
Had numerous visits and even more no-shows - new hub, cables etc. - but no fix.
I was even told it looked like I was removing the hub from the line at times - which I was not.
It actually went on for over a year and twice I was offered a contract opt-out as BT had not provided the service. Lots of compensation for down time as BT Sport channels on BT box would not work during these times.
I kept a log of the weather - and another log of the speeds. I did whenever the speeds had dropped but they didn't always drop or were not noticed when it rained.
Eventually got a helpfil visit from Openreach where he looked at his log of the noise on my line for the past couple of months and could see issues I had missed and could himslef confirm they were bad days for the wather - he was caught in one local downpour himself while on a trip out.
He arrange for the cable into the house to be replace - they was no junction box on the outside of the house.
Within two weeks they had laid a new cable in new trunking and a new connection point in the house. We've had lots of heavy rain since - but never a drop from >50Mb which is faster than the old cable.
Fibre 2 Unlimited using EE Smart Hub 2 with EE TV Box Pro (UHD/HDR) in IP mode.
Message 24 of 30
Not sure if relevant... But the IP profile for the line is 64mb. but im getting 70+ mb at the router, could that make it unstable... stats from  advanced Bt wholesale test...
dvance Test
Download Test
Download speed achieved during the test was 60.57 Mbps
For your connection, the acceptable range of speeds is 40 - 64.87 Mbps
IP Profile for your line is 64.87 Mbps
60.57 Mbps
router stats...
Firmware version:v0.31.00.10253-BT
Firmware updated:Wed Feb 16 09:21:58 2022
Board version:R01
GUI version:1.74 12_11_2020
DSL uptime:0 days,00 Hours14 Mins36 Secs
Data rate:20 Mbps / 70.695 Mbps
Maximum data rate:25.583 Mbps / 73.205 Mbps
Full Fibre (FTTP) Mode:Off
Noise margin:9.1 / 6.4
Line attenuation:6.5 / 12.7
Signal attenuation:6.4 / 14.0
VLAN id:101
Upstream error control:Off
Downstream error control:Off
64.87 Mbps
Upload Test
Upload speed achieved during the test was 18.44 Mbps
IP Profile for your line is 20 Mbps
18.44 Mbps
20 Mbps
Message 25 of 30
OK ive now lost the will to live with this....
last hour 7 drops. that cant be DLM
heres the event log during one...
14:38:40, 24 Feb.
LAN [DEL] ARP 192.168.1.138 with 2e:06:d2:ed:fd:ec from br0
14:38:40, 24 Feb.
5G Client disassociate from 2e:06:d2:ed:fd:ec (IP=192.168.1.138) RSSI=0, Rate=0Mbps
14:38:39, 24 Feb.
WHW INFO A station STA(2E:06:D2:ED:FD:EC) leave WHW infrastructure
14:38:39, 24 Feb.
5G client Mac: 2E:06:D2:ED:FD:EC Deauthentications (Reason:Deauthenticated because sending station is leaving (or has left) IBSS or ESS)
14:38:34, 24 Feb.
SIP WAN DOWN
14:38:32, 24 Feb.
DHCP device Connected: 192.168.1.193,  unknown
14:38:32, 24 Feb.
2.4G Client associate from
14:38:32, 24 Feb.
LAN [ADD] ARP 192.168.1.193 with 8e:85:80:07:c7:33 from br0(wl1)
14:38:31, 24 Feb.
Receive a DHCP request
14:38:30, 24 Feb.
SIP WAN DOWN
14:38:30, 24 Feb.
WHW INFO A station (SmartHub2)IF[2.4G](78:DD:12:9C:E4:F9):STA(8E:85:80:07:C7:33)(Legacy Device) join WHW infrastructure
14:38:30, 24 Feb.
WAN Sensing Auto sensing Complete, interface selected
14:38:30, 24 Feb.
WAN Sensing Auto sensing Running
14:38:28, 24 Feb.
14:38:27, 24 Feb.
14:38:27, 24 Feb.
WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
14:38:24, 24 Feb.
Broadband Line Id Result = No Response
14:38:23, 24 Feb.
PPP: Stopped PPP daemon(0,1,5)
14:38:23, 24 Feb.
PPP LCP Send Termination Request (User request)
14:38:23, 24 Feb.
PPP: IPCP down
14:38:23, 24 Feb.
PPP: LCP down
14:38:23, 24 Feb.
DSL Link Down: duration was 49 seconds
Message 26 of 30
Next issue.. i get an email asking me to go online and book an appointment at my convinient time..
So i click the link in the email.... it then runs fault diagnostics, then says i already logged a fault. but there is a promising  book appointment button... but no i click on it and it says.... looks like your appointment was missed?  What appointment? i  didnt make one... yet another BT thing that just doesnt work. surely a book appointment button should take you to just that, not a fault tracker?
Confused.... very!
Message 27 of 30
During my long running issues with BT I had "visit complete" and  "we called buy you were not in" messages - all incorrect.
On one occasion the visit was 30 minutes after the status was changed to visit complete.
It is hard work trying to get a fix with a fault which is not obvious.
Message 28 of 30
Mmm, "changed the circuit couplers" hopefully that was not the engineers words? I smell a bit of Bull++++ if it was.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 29 of 30
so far this morning... 15 drops... so fed up, i have now contacted gigaclear. for their fttp service as clearly BT service is not fit for purpose
Message 30 of 30
Hi @coreservers, I've not heard back from you since the engineering work was completed on the 11th of March.
I've tried to get in touch on the phone and via Private Message. I trust all is ok with your connection now and that you're happy with the broadband. If not and you need further help please post back or reply to my PM.
Cheers
John
