COMPANY-PENSIONER
Message 1 of 13
Getting Value For Money ?
Hi.
In view of the W7 EOL 14/January/2020, I purchased a new laptop. 8GB Ram/I5/512SSD/3GB Graphics.
I've not purchased tech for 10years; so, this machine  is 'QUICK'. Now the problem.
Since I had old tech, I've put off this question, until I purchased an up-2-date machine.
I run on 80/20 BT Broadband' FTTC. The problem being, I only get 80/10. Where's the rest of the 'upload speed'.  I do realise that the 'pinch point' can be anywhere. So where, router (3b), out in the street, in the local exchange, out on the core network ?
Alternatively, would it be wise to TRC a BT Broadband Engineer, to investigate, and right my upload speed. At what price ?
Any info, would be appreciated. Cheers !
Best regards. SinecoalCirph4.
Merry Christmas & Happy New Year !
12 REPLIES 12
albertj
Recognised Expert
Message 2 of 13
Re: Getting Value For Money ?
Hi @COMPANY-PENSIONER
Go to this website: https://www.dslchecker.bt.com/ and post results, please remember to remove the phone number
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
imjolly
Message 3 of 13
can you post stats from your hub  if hh6 then advanced settings then technical log information
from reading your previous posts if you feel that gives personal information then post the information from dsl uptime to noise margin
COMPANY-PENSIONER
Message 4 of 13
HH3B. Looks like I'm actioned with chores, in search of a result. In the run-up to Christmas, time is too short.
I'll revisit this item, in the New Year.
Thanks. CP
albertj
Recognised Expert
Message 5 of 13
@COMPANY-PENSIONER
OK, sounds good.
EDIT: Removed incorrect information
The HH3 is quite old now, when did you last re-contract? If you're in contract, I would recommend calling and politely ask for a new router.
pippincp
Message 6 of 13
@albertj wrote:
@COMPANY-PENSIONER
OK, sounds good.
For when you get back, if you're using the Hub 3, that looks like this:
The Instruction to access stats as follows: Troubleshooting > helpdesk - The admin password is again on card or back of the router
The HH3 is quite old now, when did you last recontract? If you're in contract, I would recommend calling and politely ask for a new router.
The stats are not accessable on VDSL with a HH3 as a separate modem is needed which holds the connection stats.
albertj
Recognised Expert
Message 7 of 13
@pippincpwrote:
@albertjwrote:
@COMPANY-PENSIONER
OK, sounds good.
Oops! Thank you. All the more reason to get a new router 🙂
COMPANY-PENSIONER
Message 8 of 13
Catch-Up.
Yep, HH3B. It's the original HH that came with the upgrade to 80/20, some long time ago.
Never been in contract. The account is subject to the all-up maximum BT Broadband Price.
CP.
imjolly
Message 9 of 13
If you have never been in fixed term contract apart from outset then you are paying to much and should negotiate a new cheaper deal and as part of negotiations ask for new hub
albertj
Recognised Expert
Message 10 of 13
Yes, was going to say! Thought BT would have been in touch in the last few years(!) to renew.
