Foiled
Message 1 of 8
Gfast - Amber availability
Hi.
on using the dslchecker website, gfast availability is listed as "amber"
Does anyone know what this means?
7 REPLIES 7
Sage
Sage
Message 2 of 8
Re: Gfast - Amber availability
The FTTP team will be able to advise you. Give them a ring. 0800 587 4787
Moderator
Moderator
Message 3 of 8
@Foiled I've seen this before when the low estimate is below the 100Mb minimum guarantee on the g fast packages.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
conrad
Recognised Expert
Message 4 of 8
There are a lot of various explanations apparently depending on which ISP you talk to.
@NeilO  until the last couple of weeks Gfast was available ( not that I can afford it) but it is now amber
Also if I check using the website, as a new customer , what I can order as Ultrafast  is only the  152Mbps package whereas previously the 300Mbps was available. I haven't bothered the FTTP team as I'm not buying it.
Foiled
Message 5 of 8
I’ve had the exact same experience as @conrad
Dslchecker says I should be able to get 330Mbps (the bt cabinet is <100m away), previously I was able to order the full gfast speeds with bt.com, but now only 150 Mbps is available. When I ordered 330Mbps with EE, EE cancelled the order as bt openworld couldn’t give them a installation date *shrug*
Hence my question of what does “amber availability” exactly mean?
Message 6 of 8
Just guessing here, I wonder if it is because there isn't sufficient capacity in the backhaul to support the volume of take up of the 330M service. I.e nothing to do with sync speed capability, but rather throughput capability.
Moderator
Moderator
Message 7 of 8
Hi Everyone,
I've emailed the G Fast product manager in BT Wholesale to see if I can get an explanation for this result, when I hear back I'll let you all know the outcome.
Cheers
Neil
Kudos”Kudos”
Moderator
Moderator
Message 8 of 8
Hi Everyone,
To clarify the amber result simply means that Openreach are recommending that the G.Fast install is done by an engineer rather than the self install option that is being trialled by them at the moment, it won't prevent you from ordering and doesn't indicate any issues with the line.
I hope that clears things up?
Cheers
Neil
Kudos”Kudos”
