Been using Google WiFi, connected to a TP Link WD-9970 modem set in bridge mode. However, I have been getting connection drop outs to some of my devices and Google support are telling me it is because I have Enable VLAN set to 101. Google WiFi apparently does not support VLAN. Modem set up like that automatically, although I read in numerous places that VLAN needed to be set to 101.
I then disabled VLAN, but Google WiFi did not, or could not pick up the connection, so I had to revert. Google support are telling me that I need to disable VLAN on my modem, factory reset Google WiFi and then set up again.
Before, I go through this pain, does anyone have any experience, or advice on this? I don’t use BTTV if that is relevant and thanks in advance for any help.
Hi @metaphor101 ,
I think it may be best to post your question on the Google Wi-Fi Community here: https://support.google.com/wifi/community?hl=en
Failing that:
1) Do you use Google WiFi for PPPoE details?
2) Does your modem work NOT using a VLAN if using another router?
2) Factory reset everything and start again if it doesn't.
But as Google Wi-Fi is heavily consumer-based, I doubt it needs to use VLAN 101. And, a quick google search for 'vlan google wifi' shows that it is not supported.
Thanks for taking the time to answer. In answer to your questions -
1. Yes
2. Don’t have one to try
3. Been done
Google Wifi does not support Vlan - it works, but just with occasional drop outs. The problem is that it does not get an internet connection if you disable Vlan on the modem. I can only assume that BT Broadband needs Vlan enabled
As you connect at the exchange via a VLAN its no wonder you can't get a connection if you disable it in the modem.
