Sage
Sage
Message 21 of 27
Re: Gradually Reduced Speed?
Can you post the connection stats from the hub? How to HERE.
Adamsheff
Message 22 of 27
Thanks pippincp.
Atm I am using the Openreach model. It has been connected for 14 days straight now. Is it ok to unplug it and plug in the HH?
Sage
Sage
Message 23 of 27
Yes it shouldn't cause any issues. If you are planning on going back to the modem later then leave it a couple of hours.
Adamsheff
Message 24 of 27
Product name: BT Hub 6A
Serial number: +084316+NQ73*****
Firmware version: SG4B1000B316
Firmware updated: 12-Dec-2017
Board version: 1.0
Gui version: 1.64.0
DSL uptime: 0 Days, 0 Hours 7 Minutes 19 Seconds
Data rate: 20.00 Mbps / 68.49 Mbps
Maximum data rate: 29156 / 69999
Noise margin: 15.4 dB / 6.3 dB
Line attenuation: 13.9 dB
Signal attenuation:
VPI / VCI: 0/38
Modulation: G_993_2_ANNEX_B
Latency type: Fast Path
Data sent / received: 0 MB Uploaded / 0 MB Downloaded
These are the stats atm with the home hub 6.
Any info would be appreciated 🙂
Sage
Sage
Message 25 of 27
Those stats look OK and your speed is within estimated range so I can't see anything being done about it. As mentioned previously it is most likely crosstalk.
Adamsheff
Message 26 of 27
Thank you! Sounds like it is all out of my control then.
Do you know if it’s likely that I will move onto a lower noise margin? How long does it normally take for that to happen?
Message 27 of 27
I rather suspect if your line is being affected by crosstalk noise, DLM will probably hold your noise margin to 6dB. Smiley Sad
