Mr_Cooke13
Message 1 of 5
Grimsby - Infinity
Hi
I checked Openreach's website and my postcode is shown as coming soon, however, I have been able to place an order successfully through BT for Infinity and also when checking my phone number on the wholesale website it shows my line to be capable of up to 80mbps.
I have tried to speak to BT in regards to this and they tell me that the exchange is not yet setup for Infinity yet I have an install date for early next week?
Is anybody able to clarify, as far as I can see, the order has been accepted and going ahead... Infact my Home Hub 5 has just been dispatched!
Thanks,
Adam
4 REPLIES 4
Message 2 of 5
Re: Grimsby - Infinity
If you use this checker it will tell what cabinet you are on and what services it can receive
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Mr_Cooke13
Message 3 of 5
FTTC Range A (Clean) 80 72.7 20 20 -- Available
I'm guessing everything is A-OK for the installation then! ;D
Message 4 of 5
I would say so but until it is actually up and running you never know with BT.
Mr_Cooke13
Message 5 of 5
Aye I noticed that from my ADSL installation at the beginning of the month!
