helenmac1cat
Message 1 of 7
[HELP/URGENT] BT Infinity Lag/Ping Spikes
Since the 8th of December I have been getting random ping spikes from 20ms (normal) to 600ms (unusable) and it's making online game not possible.
Does anyone else have this issue and is there a fix?
I have tried power-cycling the hub (HH5) and sitting closer to the hub (wifi) and it makes no difference. I have also tried 17070 option 2 and it's quiet.
6 REPLIES 6
chocolatehobnob
Message 2 of 7
Re: [HELP/URGENT] BT Infinity Lag/Ping Spikes
Hi,
Sorry I don't have any solution but I've been getting HH5 problems recently too. I wonder if you log into the HH and look in the logfile  (troubleshooting / event log / category "boot") does it indicate that the HH updated its firmware at the time your problems started?
That's what happened to mine when the problems started.
BW
Message 3 of 7
Does it help if you use an ethernet connection instead of wifi?
helenmac1cat
Message 4 of 7
Mine has been saying "Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)" for the past 6 months.
helenmac1cat
Message 5 of 7
I'm sitting right next to the HH5 and the issue still persists, so it's not to with interfereance.
Distinguished Guru
Message 6 of 7
do you mean you're still using wifi?
can you try it wired, please?
If not, I'll try again 🙂
helenmac1cat
Message 7 of 7
I tried wired, and I still get these ping spikes. Any ideas?
