dilosec
Message 31 of 71
Re: HG612 / Third Party Settings.
The previous HG612 firmware could have been several versions back - 28SP06/08.
Try reflashing HG612 with 30SP08 again - when this completes do a factory reset of the HG612 - I don't think there are any configuration changes needed.
Then connect up line from Master Socket to HG612 DSL socket, HG612 LAN1 to HH5 WAN socket - this is good to go...
MrNorma
Message 32 of 71
Reflashed and managed to do a factory reset eventually.
Plugged in DSL line anf powered it up.  DSL light flashed 3 times fast and then nothing.  Left it for 10 mins and nothing.
Kind of giving up on it for the now as my line stats will be all over the place.
MrNorma
Message 33 of 71
With another firmware upgrade I have it working. My question now is how do i see if g.inp is enabled.
Distinguished Guru
Message 34 of 71
Hooray 🙂
If not, I'll try again 🙂
Distinguished Guru
Message 35 of 71
In Status > WAN > xDSL you should see Path 0 and Path 1
MrNorma
Message 36 of 71
I see both but path1 has no stats
Distinguished Guru
Message 37 of 71
Try telnet and do
xdslcmd info --stats
You should Bearer 0 and Bearer 1 and G.INP stuff like
G.INP Framing: 18 18
G.INP lookback: 19 13
MrNorma
Message 38 of 71
cheers Ray. Will have a look in a mo.
This lol started as I lost 10mb on my download and my ping got slightly higher.
MrNorma
Message 39 of 71
very sad face...
only showing bearer 0
i have the correct firmware so it should support g.inp if it was enabled.
When my line was acctivated i had max 80/20 but after 5 days it dropped 10meg and the ping jumped up by 10ms.  A lot ofmpeoplemhad been waiting on the cabinet going live so not sure if thats made a difference.  I am no more than 100m to my cabinet.
Is there anyway to see if g.inp has been enabled?
Distinguished Guru
Message 40 of 71
It sometimes takes a while to come on
