CarlH
Message 51 of 71
Re: HG612 / Third Party Settings.
How did you get it working MrNorma I too seem to be getting just to the DSL flashing but not connecting stage?
Distinguished Guru
Message 52 of 71
If the DSL light flashes 3 times it indicates the firmware needs to be re-flashed.
If not, I'll try again 🙂
CarlH
Message 53 of 71
Is there a preferred method as done that a couple of times already?
Distinguished Guru
Message 54 of 71
You have to use the reset method not the WAN Gui method.
CarlH
Message 55 of 71
Yes done that.
The DSL light flashes many times, the 'status' screen show DSL intialising then trying to establish the link but then just keeps going around in loops failing to connect.
Plug the ECI back in and DSL establishes fine.
Not sure what else to try - could be a duff one I suppose.
Distinguished Guru
Message 56 of 71
Which firmware are you trying to load?
CarlH
Message 57 of 71
The H-Wolf B030SP08 with webgui which looks fine and loaded, it just won't seem to raise DSL at all.
Distinguished Guru
Message 58 of 71
Yes, that's the one I use and it's fine. The only problem is the somewhat fickle re-flash process. Have you tried a long reset after re-flashing the firmware?
dilosec
Message 59 of 71
Try a factory reset - press and hold the reset button for 10-15 secs, then release - this will reload the default configuration for the firmware you've just flashed - no config changes are needed.
MrNorma
Message 60 of 71
Inhad to flash the firmware 3 times in the end. I find trying to do a long reset a pain as most of the time it wouldnt reset.
The issue inhave is it takes almost 10 mins for the line to resync so i thoughtnit was a bad flash when in fact it was my line.
Whats the norm in regards to the time it takes to resync?
Also can younhave a look at the bellow stats and tell me what you think.  Im about 200m at most from my cabinet.  First 3 days of HH5 Infinity 2 i had 80/20 and now have 70/20.  Line was solid for 10 days on HH5 after it resynced from 80/20 to 70/20.
Feels like DLM is not letting go and my pings have went from around 10 to 26-30 for BBC.co.uk
 Connection Status
Help
ModeVDSL2
Traffic typePTM
DSL synchronization statusUp
DSL up time0
 Line Status
Help
 DownstreamUpstream
Attainable rate (kbit/s)7001228053
SNR margin (dB)6.115.4
Line attenuation (dB)13.90
Output power (dBmV)13.83.6
 Statistics
Help
Path 0
Path 1
 DownstreamUpstreamDownstreamUpstream
Line rate (kbit/s)70242 19999
CRC errors
FEC errors2048
HEC errors181
