MrNorma
Message 1 of 71
HG612 / Third Party Settings.
I am looking got a list of setting to setup the HG612 or any other third party modem to work with a HH5 Type A.  After a morning of googling i have yet to find working informations and just thought you guys would know best.
70 REPLIES 70
Distinguished Guru
Message 2 of 71
Re: HG612 / Third Party Settings.
Plug it in the phone socket instead of the HH5 and plug it into the red WAN socket on the HH5.
Master socket --> Modem --> HH5
If not, I'll try again 🙂
MrNorma
Message 3 of 71
Ray i tried that and the HG612 never got a dsl sync. I left the modem by itself with nothing plugged into and it still didn't get a sync.
Plug the HH5 in and it works fine...?
Distinguished Guru
Message 4 of 71
Is the HG612 unlocked?
MrNorma
Message 5 of 71
Its the actual WAN settings i was looking for?
MrNorma
Message 6 of 71
Unlocked with SP08 Original
Distinguished Guru
Message 7 of 71
What do you mean, sorry?
MrNorma
Message 8 of 71
I have just unlocked it to Firmware SP08 and i am pretty sure the WAN settings are wrong as it just sits on "initializing"
MrNorma
Message 9 of 71
That is the settings under BASIC>WAN
Distinguished Guru
Message 10 of 71
What settings do you have in Basic > PTM ?
