b19bol
Message 11 of 13
Re: HH3 for first 10 Days or Immediate swap to Draytek Vigor 2750N ?
@kanjar wrote:
White Box? The 2750N will be replacing both the Modem and the router. I should in theory be able to pre-configure it so that its a simple plug in the replacement and go, to keep disconnects to a minimum.
This be ok do you think?
You may need to consult this for settings:
http://www.draytek.co.uk/support/kb/kb_vigor_v2750_setup.html
Yeah had already found that, but thank you anyway Smiley Happy
b19bol
Message 12 of 13
@Paul1360 wrote:
Hi b19bol,
Using the Draytek 2750N are you able to see your Line stats? If so can you post them please so we can have a look
Is This the Info you require?
Draytek 2750 Line Stats
Paul1360
Expert
Message 13 of 13
Aye thats it thanks
 iechyd da
