Message 11 of 26
Re: HH5 Fortnightly Resyncs
On a positive note my 14 day resets stopped all of a sudden without me doing anything and went on for 95 days and was only reset by a power cut. Next reset also lasted longer than 14 days
Message 12 of 26
@DanMax89 wrote:
Interesting you saying that TR-069 won't trigger a reboot, but before interleaving was enabled on the line the exact same events as I posted above were seen in the logs. I assume interleaving has to be a function of DLM and nothing else.
No, that isn't what I said. I said I didn't think DLM would trigger a reboot via TR-069, it would do it directly at the DSLAM. I believe the TR-069 reboots are for a different purpose.
DanMax89
Message 13 of 26
I should note I get events like below every single morning at the same time. Is this normal? It's only after the 14 days have passed that I see the different CWMP: Initializing transaction for event code 4 VALUE CHANGE entry, which I guess shows a configuration change of some sort.
05:42:38, 28 Jun.NTP synchronization success
05:42:26, 28 Jun.NTP synchronization start
05:39:00, 28 Jun.CWMP: HDM socket closed successfully.
05:39:00, 28 Jun.CWMP: HTTP authentication success from pbthdm.x.x.x
05:39:00, 28 Jun.CWMP: HDM socket opened successfully.
05:39:00, 28 Jun.CWMP: session completed successfully
05:38:59, 28 Jun.CWMP: HDM socket closed successfully.
05:38:59, 28 Jun.CWMP: HTTP authentication success from pbthdm.x.x.x
05:38:59, 28 Jun.CWMP: HDM socket opened successfully.
05:38:58, 28 Jun.CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
05:38:57, 28 Jun.CWMP: Session start now, server: pbthdm.x.x.x, Event code:
05:38:57, 28 Jun.CWMP: Initializing transaction for event code 2 PERIODIC
Message 14 of 26
@imjolly were your reboots triggered by TR-069 messages?
Message 15 of 26
Can't remember now
DanMax89
Message 16 of 26
Should also probably mention that the resyncs on the 14th day that show the CWMP: Initializing transaction for event code 4 VALUE CHANGE are always preceeded by the PPP entries below.
05:38:58, 26 Jun.WAN connection PTM connected
05:38:57, 26 Jun.PPP IPCP Receive Configuration ACK
05:38:57, 26 Jun.PPP IPCP Send Configuration Request
05:38:56, 26 Jun.PPP IPCP Receive Configuration NAK
05:38:56, 26 Jun.PPP IPCP Send Configuration ACK
05:38:56, 26 Jun.PPP IPCP Receive Configuration Request
05:38:55, 26 Jun.PPP IPCP Send Configuration Request
05:38:55, 26 Jun.PPP CHAP Receive success : authentication successful
05:38:55, 26 Jun.PPP CHAP Receive Challenge
05:38:54, 26 Jun.PPP LCP Receive Configuration ACK
05:38:54, 26 Jun.PPP LCP Send Configuration ACK
05:38:54, 26 Jun.PPP LCP Receive Configuration Request
05:38:54, 26 Jun.PPP LCP Send Configuration Request
05:38:52, 26 Jun.2.4G WiFi auto selected channel 1 Bandwidth:20M(Reason:boot)
05:38:49, 26 Jun.2.4G WiFi scan(Reason:boot)
05:38:48, 26 Jun.5G WiFi auto selected channel 36 Bandwidth:80M(Reason:boot)
05:38:42, 26 Jun.5G WiFi scan(Reason:boot)
05:38:38, 26 Jun.DSL Link Up: Down Rate=78203Kbps, Up Rate=20000Kbps; SNR Margin Down=6.4dB, Up=10.0dB
05:38:29, 26 Jun.Booting firmware v0.07.05.0A13-BT (Thu Oct 15 14:28:46 2015)
05:38:28, 26 Jun.System start Button press (PowerButton)
05:38:26, 26 Jun.5G WiFi auto selected channel 36 Bandwidth:80M(Reason:boot)
05:38:19, 26 Jun.5G WiFi scan(Reason:boot)
Message 17 of 26
Thinking about it, rebooting a HH that was connected to a separate modem wouldn't cause a re-sync of the line so no point in DLM issuing a TR-069 command to initiate a reboot (it wouldn't know if it was talking to a standalone hub or modem connected hub). Nor would it have any effect on a third party router.
DanMax89
Message 18 of 26
Is there anyway to have a Mod look at this? It genuinely infuriates me having to deal with interleaving on a line I know performs fine on an open profile <200m from cabinet and if my Hub is showing unusual behaviour this could point to an issue with the hardware. I long for the days of adsl where I could just turn interleaving off and that was that.
Message 19 of 26
ISP's have no control over DLM whatsoever, it is purely automatic and can only be reset by an Openreach engineer.
DanMax89
Message 20 of 26
@licquorice I understand that, I'm just trying to determine if it is possible to have the DLM reset (as I've done before) then switch to a third party router/modem combo to avoid any further remote resyncs.
