Message 51 of 283
Re: HH5 New Software Version 4.7.5.1.83.8.204
just looks as if it needs an install command have you tried a single restart of the hub
DavidCo
Expert
Message 52 of 283
No I havn't tried that, recently I have been having 'few' disconnects & didn't want to 'rock the boat'
But as my VDSL has just done its thing after 21 days...........
I'll give it a goSmiley Wink
prinknash
Expert
Message 53 of 283
DavidCo,
In my case, the "5A-FixMajorUpgrade-4.1" etc. file was downloaded on 30 December. But my HH5 hasn't moved on to the new firmware. I'm inclined to think that the "FixMajorUpgrade" file is something that needs to be in place before the new firmware is installed, rather than being the new firmware itself. But who knows?
What seems to be different in your case is the multiple downloading of the file and the fact that your "Last updated" date aparently reflects when you downloaded the FixMajorUpgrade file - because the date for me is still last August.
As John says - and as I suggested yesterday - a reboot (if you haven't had one for a while) might get things unstuck.
p
DavidCo
Expert
Message 54 of 283
.204 it is.
Now let us see!
I hope that it helps with the disconnect thing. Then, if, my wife can have her b****y BT TV.
prinknash
Expert
Message 55 of 283
@DavidCo wrote:
.204 it is.
Now let us see!
Good luck!
p
DavidCo
Expert
Message 56 of 283
The TR069 log showed a lot of 'Download' when I did a restart so I think you are correct.
I now have to figure out what the TV thing entails. I am out of contract.
Thanks allSmiley Happy
gutted
Message 57 of 283
My hh5 has just rebooted and now shows software updated  21/01/15 but showing old version still
DavidCo
Expert
Message 58 of 283
Look at post 50 and check your TR069 log.
If you get stuff like that try a restart after a couple of entries.
sammy4703
Message 59 of 283
For anyone running RouterStatsHub5A, you'll need to change the Stats URL in More Advanced Settings to /index.cgi?active_page=9141.
plymchris
Message 60 of 283
My HH5 rebooted this morning and I discovered the new firmware has been successfully installed.
Do any of the more learned members know what benefits this will bring? I have already noticed a slight download speed increase, together with a corresponding increase in IP profile (from 47 to 49 download). This could be just a coincidence of course.
