YoungunAK54
Newbie
Message 1 of 7
HH5 Resetting daily
Is anyone else experiencing problems with their HomeHub 5 resetting/rebooting?
My started to reboot itself a few months and the frequency is increasing.
It is now rebooting almost daily!
Very annoying when your busy online getting sudenly kicked off.
It also happens when there is no traffic, like last night I was awake when I saw the HH5 flash orange and my mobile phone vibrated to indicate it has lost Wifi.
The eventlog is full of information that I don't understand. for example
08:45:37, 06 Dec. IN: BLOCK [16] Remote administration (TCP 192.186.133.75:31301-​>86.183.252.12:8080 on ppp3)
08:41:25, 06 Dec. (29826.410000) Admin login successful by 192.168.1.71 on HTTP
08:30:16, 06 Dec. IN: BLOCK [16] Remote administration (ICMP type 8 code 0 203.178.148.19-​>86.183.252.12 on ppp3)
08:28:23, 06 Dec. (29044.660000) OpenWiFi IPSec connection is down
08:19:15, 06 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.71:51331-​>213.228.196.134:80 on ppp3)
08:18:32, 06 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.71:51292-​>213.228.196.134:80 on ppp3)
08:17:10, 06 Dec. (28371.610000) Lease for IP 192.168.1.64 renewed by host Viera-​GT50 (MAC 24:ec:99:fa:c1:89). Lease duration: 1440 min
08:17:10, 06 Dec. (28371.610000) Device connected: Hostname: Viera-​GT50 IP: 192.168.1.64 MAC: 24:ec:99:fa:c1:89 Lease time: 1440 min. Link rate: 130.0 Mbps
But if I filter for boot events you can see the frequency of the reboots
00:24:35, 06 Dec. ( 15.710000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
18:28:52, 04 Dec. ( 15.720000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
12:33:52, 03 Dec. ( 15.760000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
06:40:00, 02 Dec. ( 16.770000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
00:44:03, 01 Dec. ( 15.730000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
18:49:16, 29 Nov. ( 17.230000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
07:21:44, 27 Nov. ( 15.730000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
01:11:29, 26 Nov. ( 15.790000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
19:16:23, 24 Nov. ( 15.780000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
Any ideas on how I can get help on this issue.
BT appear to be ignoring my email requests for help.
6 REPLIES 6
Distinguished Guru
Message 2 of 7
Re: HH5 Resetting daily
I suggest you try a factory reset of the hub
http://bt.custhelp.com/app/answers/detail/a_id/11386/~/how-do-i-reset-my-bt-home-hub-to-its-factory-...
If not, I'll try again 🙂
YoungunAK54
Newbie
Message 3 of 7
We I tried a factory reset.
The HH5 rebooted itself 22hrs later 😞
Message 4 of 7
can you go to hub manager then troubleshooting then helpdesk and post stats 1-12 please  your wifi lease time is set to renew daily have you tried changing that in HH5 to renew every 21 days?
YoungunAK54
Newbie
Message 5 of 7
Here is my EventLog
1. Product name: BT Home Hub
2. Serial number: +068343+NQ34338093
3. Firmware version: Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated 28/04/14
4. Board version: BT Hub 5A
5. VDSL uptime: 0 days, 00:50:08
6. Data rate: 19999 / 79995
7. Maximum data rate: 27448 / 80583
8. Noise margin: 14.9 / 6.9
9. Line attenuation: 0.0 / 15.1
10. Signal attenuation: 0.0 / 15.1
11. Data sent/received: 2.3 MB / 9.4 MB
12. Broadband username: bthomehub@btbroadband.com
I've set the lease time to 21days following your advice. But based on the VDSL uptime this goes back to zero after each apparent reset.
the latest event look, filtered by 'Boot'
19:24:52, 08 Dec. ( 15.320000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
13:00:01, 07 Dec. ( 15.900000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
09:52:10, 06 Dec. ( 14.890000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
Message 6 of 7
It should only revert to 1 day after a factory reset and should maintain the 21 days with a simple restart
danielpercy
Message 7 of 7
There is something wrong with the 5A software-wise - I've had two of them on a line that is perfectly stable with a 4, and they both restart like this (same error messages etc) pretty much every day.
Setting the lease timer long won't change the reboot rate....
