Message 11 of 22
Re: HH5 constantly dropping connection and restarting
Then need to try test socket with filter and see if that helps stabilise connection.  Were your extension sockets wired to back of master front plate?
was quiet line test done with cordless phone as that often has dull hum. Corded should be quiet with no noise
Message 12 of 22
Test it as shown here.
Testing from the test socket
As @imjolly has said, all extensions should be connected at the back of the faceplate, as shown here.
Extension wiring connection point
And finally a picture showing what to check for, on your wiring, as wires can be teed in elsewhere.
Has your Infinity Installation been wired correctly?
glenhill68
Expert
Message 13 of 22
I had the same with the HH5. Changed to a Smart Hub and this no longer happens.
fairview-neil
Message 14 of 22
Looks very similar to this thread to me.
https://community.bt.com/t5/BT-Infinity-Speed-Connection/HH5-Constant-Connection-drops/td-p/1770629/...
The rates in my HH5 event log have been fluctuating periodically as it presumably tries to work out what is possible?
Some examples from one end of the spectrum to the other:
DSL Link Up: Down Rate=76481Kbps Up Rate=15346Kbps; SNR Margin Down=3.2dB Up=5.7dB
DSL Link Up: Down Rate=77280Kbps Up Rate=15369Kbps; SNR Margin Down=3.3dB Up=5.8dB
The SNR Margins are quite different between Up and Down, is this normal?
fairview-neil
Message 15 of 22
Extensions definitely wired correctly and the faceplate sorted out my previous problems.
I think this has restarted around the time of the speed upgrades.
On the DSLChecker output it has much lower numbers in the Line Rate section, more like my previous limit of around 52Mbps.
What do these numbers tell us?
Message 16 of 22
Can you post router stats - troubleshooting then help desk
fairview-neil
Message 17 of 22
1.
Product Name:
HomeHub5
2.
Serial number:
+076286+1542003477
3.
Firmware version:
v0.07.06.01239-BT (Type B) Last updated 7/3/2017
4.
Board version:
01
5.
VDSL uptime:
1 days, 00:00:04
6.
Data Rate:
15455 / 76335
7.
Maximum Data Rate:
15286 / 77132
8.
Noise Margin:
5.6 / 3.3
9.
Line Attenuation:
30.2 / 21.8
10.
Signal Attenuation:
0.0 / 0.0
11.
Data sent/received:
850.0 MB / 10.8 GB
12.
Broadband username:
bthomehub@btbroadband.com
Message 18 of 22
Connection is far better than the dslchecker and at present you are not 1 day without drop. Wonder how long it will last
was quiet line test with cordless phone instead of corded?
Message 19 of 22
Its the low noise margin that is causing the disconnections. BT have given people more speed, by lowering the target noise margin, but that can make the line unstable, and cause disconnects.
As a matter of interest, are you using any powerline adapters or broadband extenders on your home network?
fairview-neil
Message 20 of 22
Quite line test was a corded phone (a BT Converse).
No powerline extenders, I have Cat 5e wired around the house and a patch panel and 8-port switch connected to the HH5.
Here's the most recent log of connection failures, I must be due one shortly.....
21:32:31
13-Dec
 DSL Link Down: duration was 93477 seconds
19:34:09
12-Dec
 DSL Link Down: duration was 86900 seconds
19:25:23
11-Dec
 DSL Link Down: duration was 170329 seconds
20:06:08
09-Dec
 DSL Link Down: duration was 27983 seconds
12:19:20
09-Dec
 DSL Link Down: duration was 142610 seconds
20:42:05
07-Dec
 DSL Link Down: duration was 134770 seconds
07:15:30
06-Dec
 DSL Link Down: duration was 2279 seconds
06:37:05
06-Dec
 DSL Link Down: duration was 40595 seconds
19:20:04
05-Dec
 DSL Link Down: duration was 94432 seconds
17:05:47
04-Dec
 DSL Link Down: duration was 10163 seconds
21:55:35
03-Dec
 DSL Link Down: duration was 6184 seconds
20:12:06
03-Dec
 DSL Link Down: duration was 9765 seconds
17:28:56
03-Dec
 DSL Link Down: duration was 58637 seconds
19:05:45
01-Dec
 DSL Link Down: duration was 1983 seconds
18:32:16
01-Dec
 DSL Link Down: duration was 76679 seconds
21:13:52
30-Nov
 DSL Link Down: duration was 30190 seconds
12:50:16
30-Nov
 DSL Link Down: duration was 146157 seconds
20:13:54
28-Nov
 DSL Link Down: duration was 5033 seconds
18:49:36
28-Nov
 DSL Link Down: duration was 76146 seconds
21:40:04
27-Nov
 DSL Link Down: duration was 9191 seconds
19:06:28
27-Nov
 DSL Link Down: duration was 78838 seconds
21:12:05
26-Nov
 DSL Link Down: duration was 7023 seconds
19:14:36
26-Nov
 DSL Link Down: duration was 2379 seconds
18:34:31
26-Nov
 DSL Link Down: duration was 29147 seconds
10:28:19
26-Nov
 DSL Link Down: duration was 45253 seconds
21:53:40
25-Nov
 DSL Link Down: duration was 10365 seconds
19:00:30
25-Nov
 DSL Link Down: duration was 40409 seconds
07:46:35
25-Nov
 DSL Link Down: duration was 497718 seconds
