AndyBird
Message 1 of 3
HH5 dropping connection 5 times a day
I’ve scoured this forum and saw someone else who did all of the following and ended up with a replacement router which solved their problem.
I’ve done the quiet line test and the line is silent. Below are the first 12 lines from troubleshooting / helpdesk:
1. Product name: BT Home Hub
2. Serial number: +068342+NQ34259226
3. Firmware version: Software version 4.7.5.1.83.8.236.1.2 (Type A) Last updated 13/07/17
4. Board version: BT Hub 5A
5. DSL uptime: 0 days, 00:17:20
6. Data rate: 19978 / 55749
7. Maximum data rate: 21147 / 60662
8. Noise margin: 6.0 / 3.7
9. Line attenuation: 18.6 / 16.0
10. Signal attenuation: 18.6 / 15.5
11. Data sent/received: 10.1 GB / 64.1 GB
12. Broadband username: bthomehub@btbroadband.com
If anyone can help with possible solutions I’d be very grateful. Thanks!
2 REPLIES 2
NeilO
Moderator
Moderator
Message 2 of 3
Re: HH5 dropping connection 5 times a day
@AndyBird  I'm sorry to see that your connection is dropping. Have you tried connecting your Hub to the test socket to see if this helps?
imjolly
Message 3 of 3
really surprised your connection speed is as good compared to attainable if dropping 5 times on a daily basis  you would normally expect a high noise margin and probably a banded profile
