smurphy
Message 21 of 37
Re: HH5 connection issues once again.
Thanks for merging Ray,I willpost them when I get home.
John
smurphy
Message 22 of 37
1. Product name:BT Home Hub
2. Serial number:+068543+NQ45021554
3. Firmware version:Software version 4.7.5.1.83.8.204 (Type A) Last updated 16/02/15
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 02:12:48
6. Data rate:19999 / 79995
7. Maximum data rate:31760 / 78581
8. Noise margin:14.9 / 6.3
9. Line attenuation:15.9 / 14.2
10. Signal attenuation:16.0 / 14.2
11. Data sent/received:639.8 MB / 18.2 GB
12. Broadband username:bthomehub@btbroadband.com
Distinguished Guru
Message 23 of 37
Well, that's synced at full speed 80/20.
Are you using Netflix on a wireless connection?
If not, I'll try again 🙂
smurphy
Message 24 of 37
I am using an ethernet run under the floor to a network switch then distrobuted throughout the downstairs.
When it drops out I look at the router and the blue streak is flashing and the hub stats show a new uptime of mins/seconds.
I have checked everything I can at my end.
I will reset this new hub later and see if it improves but I have zero confidence at the moment.
smurphy
Message 25 of 37
Sorry I should add every item is hardwired, apart from phones/ipads.
Distinguished Guru
Message 26 of 37
You could always get a new router and flog the HH5 at auction.
smurphy
Message 27 of 37
Thanks for the advice Ray, Can I please get some mod help now or I may as well get hlc involved.
Barry57
Expert
Message 28 of 37
Agree Ray about not using the hub
From page 1 from over a month ago  07-02-2015
smurphy:
The main reason is my security cameras.....
Barry:
 The unlocked modems either eci/r or hg612 3b and asus ac68u seem a very popular set up on here.
Thanks k you for the advice on modem/router change but I'm not buying one on principle
pippinc:
Stick to them and be at the mercy of your ISP.  The choice is of course yours.p:
Ray & security cameras (bt issued?) & other requirements.
Another option is to request a boost engineer and accept the £130 ish +vat  bill charge if no fault is found on the line as the hh5 has already been replaced.
Moderator-Retired
Message 29 of 37
Hi smurphy,
Thanks for your post.
Can you send me in your details using the "Contact The Mods" link found in my profile and I will take a look into this for you.
Cheers,
OlgaC
onslow
Message 30 of 37
The simplest - and free - way to check whether the homehub router is at fault, is to temporarily remove the router; plug your PC ethernet cable directly into the BT Openreach modem; and then run the ppp layer directly on your PC..
Configuration like this:
(For Vista, from http://windows.microsoft.com/en-gb/windows-vista/create-a-pppoe-connection-to-the-internet )
