P-a-u-l
Message 1 of 17
HH5 what is the best replacement for this please
Please can someone advise on what the best direct plug n play replacement is I am fed up with my 2nd replacement brand new HH5 rebooting itself without warning due to the dreaded watchdog reset once or twice a day even with wifi enabled after the latest firmware upgrade!
Thank You
16 REPLIES 16
Distinguished Guru
Message 2 of 17
Re: HH5 what is the best replacement for this please
There's a TP Link TD W9980
If not, I'll try again 🙂
Message 3 of 17
..............which I can recommend from personal experience.
Barry57
Expert
Message 4 of 17
I've become a big fan of using separate modem and router setup since the  ^Guru's^ recommended them as an option for my line.
eci/r or hg612 3b modem* hooked upto a high end asus rt-ac68u seems a very popular combination on here. Also I believe the ac68u  works with the mulit cast stuff for the tv box.
Thats seem to be the biggest issues with 3rd party routers /all in ones. Getting the advanced multi cast settings for the extra tv channels, correctly set up.   {judging by the number of post on here.}
If you have the tv box thingy then it might be less of  set up "head-scratcher "  to keep the hh5 as just a simple router hooked upto an ecr/r or hg612 3b. Being all bt based everything "just works".
I have a unlocked eci/r (I'm on a eci street box)  for the line info & old tomato linksys router & don't have any update issues or disconnects.
*{With The unlocked modems you can also see the line stats and switch on/off certain options as well..}
gazpot0111645
Message 5 of 17
I have been using the Asus DSL-N66U. Much higher quality than the HH5. Doesnt disconnect so much and has features to tweak your link for a more stable or high performance connection. Wireless has got to be 10 time better.
Message 6 of 17
Interesting, it has bad reviews for stability on Amazon.
Distinguished Guru
Message 7 of 17
Well he did say "Doesnt disconnect so much"
gazpot0111645
Message 8 of 17
My HH5 disconnected about 10-20 times a day. Now the Asus DSL-N66U disconnects maybe every 1-2 days. A recent firmware has just been released for it which I believe fixed alot of stability issues.
mitchgoeswild
Message 9 of 17
Hi I am interested in the one you recommend TP Link TD W9980. Will this just working straight away? I have never bought a 3rd party router before. I am also having the HH5 disconnection issue like alot off others on here are experiencing
Message 10 of 17
Yep, pretty much plug and play. Just select BT VDSL in the quick setup, enter homehub@btbroadband.com as the user name, BT for password.
