Message 1 of 8
HH6 - amber light whilst away
Twice in the last month whilst we've  been away our BT homehub 6 has been unreachable, which we've noticed when we've been trying to access CCTV and IP camera's etc. On returning there has been a solid amber light on the Homehub which was seemingly resolved by restarting the router.  Although this has happened very occasionally before, not this frequently ie it's happened twice in the last few weeks, both while away which is a big frustration with our smart systems not being reachable. Any ideas, or similar experiences....or is the HH6 faulty?
Thanks 🙂
7 REPLIES 7
Message 2 of 8
Re: HH6 - amber light whilst away
is there any line noise. Dial 17070 option 2 should be silent and best with corded phone
post stats from advanced settings then technical log information
enter phone number and post results remember delete number  http://www.dslchecker.bt.com/
Moderator
Moderator
Message 3 of 8
Hi @Stukrugen and welcome back.
Sorry you're having a few problems. I'm sure we'll be able to help. Can you post the details requested by @imjolly and we'll take it from there.
Cheers
David
Message 4 of 8
Hi,
sorry for the delay:
Connection has been stable since we returned. Thank you
1. No noise heard on line
2. This is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
+084319+NQ71717413
Firmware version:
SG4B1000E01E
Firmware updated:
29-Aug-2019
Board version:
1.0
Gui version:
1.105.0
DSL uptime:
4 Days, 21 Hours 14 Minutes 30 Seconds
Data rate:
20.00 Mbps / 79.20 Mbps
Maximum data rate:
27839 / 81081
Noise margin:
15.7 dB / 6.4 dB
Line attenuation:
10.9 dB
Signal attenuation:
0 dB / 10.9 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
7428 MB Uploaded / 145209 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-Cyberdyne
2.4 GHz wireless channel:
Smart (Channel 6)
5 GHz wireless network name:
BTHub6-Cyberdyne
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
F4:6B:EF:39:73:1F
Software variant:
Boot loader:
7.33.1
Message 5 of 8
3.
VDSL Range A (Clean)8071.4201965.7AvailableAvailable--
VDSL Range B (Impacted)8069.7201963.6AvailableAvailable--
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 2.5--1 to 4Available----
ADSL MaxUp to 2--1 to 3.5Available----
WBC Fixed Rate1 ----Available----
Max Observed Downstream Speed (Mbps)78.85
Max Upstream Observed Speed (Mbps)20
Observed Date2019-09-25
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapN
VRIN
NTEFaceplateN
Last Test Date18-09-2019
Moderator
Moderator
Message 6 of 8
Hi @Stukrugen ,
Thanks for posting the stats. Everything looks ok so I suspect you may have an intermittent fault which will be difficult to pin down. Your best bet is to keep an eye on things and hope the connection drops when you're there. If that happens check for any noise on the line and let us know.
Cheers
David
Message 7 of 8
Hub is still going down every couple of weeks. Come home from work today and the Hub has a solid amber light, no connection, and which is only cured by restarting the Hub, until the next time. Do you think this is indicating a faulty hub? It's strange how it's every couple of weeks, usually a Monday or Tuesday each time.
Message 8 of 8
I thought that the 14 day reboot was a regular thing with BT kit, or at least it used to be, my hh6 used to get stuck with the green light of doom which is why I switched back to the hh5 and later retired it for a 3rd party replacement.
