Twice in the last month whilst we've been away our BT homehub 6 has been unreachable, which we've noticed when we've been trying to access CCTV and IP camera's etc. On returning there has been a solid amber light on the Homehub which was seemingly resolved by restarting the router. Although this has happened very occasionally before, not this frequently ie it's happened twice in the last few weeks, both while away which is a big frustration with our smart systems not being reachable. Any ideas, or similar experiences....or is the HH6 faulty?
Thanks 🙂
is there any line noise. Dial 17070 option 2 should be silent and best with corded phone
post stats from advanced settings then technical log information
enter phone number and post results remember delete number http://www.dslchecker.bt.com/
Hi @Stukrugen and welcome back.
Sorry you're having a few problems. I'm sure we'll be able to help. Can you post the details requested by @imjolly and we'll take it from there.
Cheers
David
Hi,
sorry for the delay:
Connection has been stable since we returned. Thank you
1. No noise heard on line
2. This is a list of your BT Smart Hub settings and current statistics.
BT Hub 6A
+084319+NQ71717413
SG4B1000E01E
29-Aug-2019
1.0
1.105.0
4 Days, 21 Hours 14 Minutes 30 Seconds
20.00 Mbps / 79.20 Mbps
27839 / 81081
15.7 dB / 6.4 dB
10.9 dB
0 dB / 10.9 dB
0/38
G_993_2_ANNEX_B
Fast Path
7428 MB Uploaded / 145209 MB Downloaded
bthomehub@btbroadband.com
Active
BTHub6-Cyberdyne
Smart (Channel 6)
BTHub6-Cyberdyne
Smart (Channel 36)
WPA2 (Recommended)
Mode 1
On
F4:6B:EF:39:73:1F
7.33.1
3.
VDSL Range A (Clean) | 80 | 71.4 | 20 | 19 | 65.7 | Available | Available | -- | |
VDSL Range B (Impacted) | 80 | 69.7 | 20 | 19 | 63.6 | Available | Available | -- | |
FTTP on Demand | 330 | 30 | -- | Available | -- | -- | |||
WBC ADSL 2+ | Up to 2.5 | -- | 1 to 4 | Available | -- | -- | |||
ADSL Max | Up to 2 | -- | 1 to 3.5 | Available | -- | -- | |||
WBC Fixed Rate | 1 | -- | -- | Available | -- | -- | |||
Max Observed Downstream Speed (Mbps) | 78.85 | ||||||||
Max Upstream Observed Speed (Mbps) | 20 | ||||||||
Observed Date | 2019-09-25 | ||||||||
VDSL Multicast | -- | -- | -- | Available | -- | -- | |||
ADSL Multicast | -- | -- | -- | Available | -- | -- | |||
Bridge Tap | N | ||||||||
VRI | N | ||||||||
NTEFaceplate | N | ||||||||
Last Test Date | 18-09-2019 |
Hi @Stukrugen ,
Thanks for posting the stats. Everything looks ok so I suspect you may have an intermittent fault which will be difficult to pin down. Your best bet is to keep an eye on things and hope the connection drops when you're there. If that happens check for any noise on the line and let us know.
Cheers
David
I thought that the 14 day reboot was a regular thing with BT kit, or at least it used to be, my hh6 used to get stuck with the green light of doom which is why I switched back to the hh5 and later retired it for a 3rd party replacement.
