user1717
Message 1 of 12
HH6 data sent and received
My HH6 in 2.5 days sent 4498mb and received 17579mb, I do not normally send much data. Is it possible from the HH6 logs to tell which device sent it?
11 REPLIES 11
licquorice
Message 2 of 12
Re: HH6 data sent and received
No
imjolly
Message 3 of 12
Go to my network in hh6 and you can see the usage for each device since last hub reset.
user1717
Message 4 of 12
Cheers for that. Would you happen to know how long the stats on the My devices screen are a running total over, as the sends and receives go up and down on a daily basis.
imjolly
Message 5 of 12
The figures a cumulative since the last reset of the hub. After reset they are back to zero
user1717
Message 6 of 12
When you say last reset of the hub do you mean the little reset switch on the back of the hub?
imjolly
Message 7 of 12
If you reset the hub by pressing the reset button or switch hub off then I find cumulative data is lost and starts again
user1717
Message 8 of 12
In advanced settings / broadband the send and receive figures zero after each power cycle or reboot.
The devices in the My Network device list never zero but increase or decrease depending on use. I guess they are a running total over 3, 6 or 9 months but can not be sure. The largest received at the moment is 687.24gb but laptops for email and surfing hover about 390mb sent 6.2gb received.
Rob364
Message 9 of 12
If you are using Win10 on your laptops you can get the last 30 days usage from settings>network&internet>Data Usage
imjolly
Message 10 of 12
in my HH6 if I go to advanced settings/my network/my devices I can see amount of data uploaded/downloaded by device since my last hub reset
