GGG
Message 1 of 12
HUB 6 firmware UPDATE 27.7.17 - DNS server is not responding please help
11 REPLIES 11
Sage
Sage
Message 2 of 12
Re: HUB 6 firmware UPDATE 27.7.17 - DNS server is not responding please help
No other information but the title of your thread?
Have you tried changing DNS servers on the device you are using?
GGG
Message 3 of 12
Thanks for your reply..
It looks that it is not possible to change the DNS in the device I am using... HH6 does not give this possiiblity?
I am in the office right now as at home nothing is working... so I cannot test it...
I did try yesterday night but I could not change the DNS ... somebody of the forum suggested the 8.8.8.8 and 8.8.8.4 but I cannot get there in the HUB6 I have which is this this one
https://arstechnica.co.uk/gadgets/2016/06/bt-smart-hub-home-hub-6-details/
All the best
Gian
Sage
Sage
Message 4 of 12
That's correct, the DNS can not be changed in a BT Hub.
Try a pinhole reset of the hub holding the recessed button in for 20 seconds.
 http://bt.custhelp.com/app/answers/detail/a_id/11386/~/how-do-i-reset-my-bt-hub-to-its-factory-sett...
GGG
Message 5 of 12
I've already did it... yesterday and at that point I had also the Fireware updated...
Before this update the  HUB could work for two weeks and then down for a day and then back... now I tried this am and usual problem on the DNS...
Can I change the HUB and buy something that works..?
Sage
Sage
Message 6 of 12
Yes, any third party VDSL router will be better than a BT hub. Depends on your budget. They can be obtained from £35 upwards depending on your needs and if you want to future-proof.
GGG
Message 7 of 12
Thank you,
2 years ago I was with EE fiber which in any case was using BT fiber lines and it was warking really well... then BT came out with a good offer which EE was not willing to give so I did change UNFORTUNATELY...
The difference was that I had to use EE router and then I was using this
The NETGEAR AC1600 Smart WiFi Router
wired to their router...  because the Wireless strenghts was much better than the one of EE
It was really reliable... but for some reasons I could not connect directly Netgear to the line but I had to use EE router as bypass...
I still have NETGEAR ... do you think I can use it and connect it directly to the line instead of the HUB6?
If not can you please suggest a good option?
I have hardrives connected to the HUB I need a good router one..
All the best
Gian
Sage
Sage
Message 8 of 12
Your netgear should work seemlessly as it is a VDSL router.
IIRC the smart setup wizard it has should autoconfig everything for you. You can then make any custom changes you wish.
GGG
Message 9 of 12
Thank you...
Using Netgear, I guess I still have to change the DNS..  do you have a configuration to suggest?
All teh best
Gian
Message 10 of 12
use the DNS's suggested in your first post
