albassoul
Message 1 of 13
Halved infinity 2
Hi All,
Suddenly my infinity 2 dropped to half after a healthy 75 down and 20 up.
Called and support logged a fault last evening; Openreach engineer came and changed a cable up the pole, he assured me it was fixed and left, and told me this is the best I can get.
Unfortunately is now worse:
1. Product Name: HomeHub5
2. Serial number: +076286+1615001524
3. Firmware version: v0.07.07.03230-BT (Type B) Last updated 7/6/2018
4. Board version: 01A
5. VDSL uptime: 0 days, 00:28:35
6. Data Rate: 13917 / 34771
7. Maximum Data Rate: 13917 / 40541
8. Noise Margin: 6.1 / 6.1
9. Line Attenuation: 22.1 / 17.3
10. Signal Attenuation: 0.0 / 0.0
11. Data sent/received: 80.3 MB / 153.4 MB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: No
14. 2.4GHz wireless network/SSID: A2
15. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 300 Mb/s))
16. 2.4GHz wireless security: WPA2 Only (Recommended)
17. 2.4GHz wireless channel: 1
18. 5GHz wireless network/SSID: A5
19. 5GHz wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5GHz wireless security: WPA2 Only (Recommended)
21. 5GHz wireless channel: 100
22. Firewall: Default
23. MAC Address: d4:63:fe:9a:62:4e
24. Software variant: -
25. Boot loader: 0.5.1-BT (Wed Nov 12 11:52:05 2014)
After entering my tel no in Openreach website I get:
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
High Low High Low
VDSL Range A (Clean) 77.4 55 20 17.4 47.3 Available Available --
VDSL Range B (Impacted) 67.7 43.2 20 12.1 35 Available Available --
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand 330 30 -- Available -- --
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 6 -- 4 to 8 Available -- --
ADSL Max Up to 5 -- 3.5 to 7.5 Available -- --
WBC Fixed Rate 2 -- -- Available -- --
Other Offerings
Availability Date
VDSL Multicast -- -- -- Available -- --
ADSL Multicast -- -- -- Available -- --
Premise environment
Status
Bridge Tap N
VRI N
NTEFaceplate N
Last Test Date 19-05-2018
I’m not sure if BT staff here can help please?
Message 2 of 13
Re: Halved infinity 2
are you using the test scocket with a filter to see if that helps?
try quiet line test  dial 17070 option 2  should be quiet and best with corded phone
albassoul
Message 3 of 13
I did, and also the fibre openereach engineer that left 30 mins ago did..
Message 4 of 13
There is nothing in information you have posted which suggests you will get speed within dslchecker estimate you need to get another engineer visit possibly boost engineer to see why you cannot get back to previous speed
albassoul
Message 5 of 13
Can customer support login and check my help desk details in homehub 5b?
I’m still on the phone with them and they want to book another engineer to come and verify my speeds as the failed one today cleared the job as fixed! They’re telling me they can’t login and see but the guy from last evening managed to..
Message 6 of 13
you are going to need another engineer visit and possibly best with boost engineer to see if can get speed back to where it was
albassoul
Message 7 of 13
I asked but he didn’t know what the boost engineer is..
He booked me one for Tuesday, if magically speed will come back by Monday I’ll cancel the booking.
Can a mod here maybe help me to make sure I get a boost engineer as advised please?
Message 8 of 13
I think you should wait until engineer has been and then post stats. Hopefully engineer will fix it
albassoul
Message 9 of 13
finally got confirmation engineer with boost addon will arrive on tuesday
took some snapshots to make things more easy to read. will repost again after engineers visit
bt wholesale speedtest.JPGbtspeedtest.JPGhelpdesk.JPGInkeddslcheckJPG_LI.jpg
albassoul
Message 10 of 13
Just a quick update,
Boost Engineer showed up today instead of tomorrow, he traced the fault outside my property and changed some cables, took him 3 hours in total, very pleased with him.
When he finished he got me synced at around 72 meg, however after he cleared the fault he also had to reset DLM and im now synced at 62 and practically getting 57-58 in speed tests.
im uploading some screenshots sync before and after DLM reset after he finished working and also details from helpdesk in my homehub:
do u think i will get better speeds hopefully? also noticed my ping sits at 20's when before i had 7-8 ms
