imjolly
Message 11 of 13
Re: Halved infinity 2
you are on a Huawei cab and would previously had G.INP activated which would have given a boost to your conenction speed  however the DLM reset will stop the G.INP but as DLM sees line stable now work complete then if will activate G.INP and you should get back to where you were  might take couple of weeks just maintain stable connection
albassoul
Message 12 of 13
Hi,
wan reconnected by itself and see attached new details
its much better than before, but still not what i used to get full 75 meg on downloads.. now getting between 67-68.
Do u think there is still room for DLM to further improve it ? g.inp/vectoring enabled and lower noise margin?
imjolly
Message 13 of 13
I think just stay connected as it does not look like G.INP active as that normally reduces noise margin - so a bit more possible but patience
